Issue Fixed.
Thanks everyone!![]()
dellfanboy,
Nero isn't recognizing the drive correctly. The first thing you should try is using ImgBurn instead of Nero. There's a very good chance that single change will solve your immediate problem. If you do still have the same problem when using ImgBurn, post back here with the ImgBurn log.
It's not connected to your current problem, but the log shows you were trying to fill a CMC MAG disk to 99.97% of capacity...burning at 8x. That media isn't very good, and is likely to give you problems. Taiyo Yuden and Verbatim are good media, or you can take a look at this page, which will help you figure out other good media choices.
I see this was your first post here, so welcome to VideoHelp. -
What VegasBud said. And Nero 6 is not fully compatible with Vista. You need Nero 7 or higher to be fully compatible. But I have found for just burning that ImgBurn works much better. For media, I would recommend Taiyo Yuden or Verbatim to try. CMC works sometimes, but may give inconsistent results. It's really not worth using cheap media if you can't depend on it.
If you really want to use cheap media, limit the size to about 200MB less than the disc capacity or about 80 - 90%. Cheaper media has the most problems at the outer edge of the disc, near the 100% area.
BTW, you might want to edit out your Nero serial number from your post, the first line of your log. If not, others may steal that serial # and make updates very difficult for you in the future.
I'll do that for you now. Moderator redwudz
No audio when burning dvd using AVStoDVD (log posted)
By aikipaul in forum Authoring (DVD)Replies: 4Last Post: 4th Oct 2010, 11:15 -
Dell Inspiron 1564 fan issues
By alintatoc in forum ComputerReplies: 3Last Post: 25th Apr 2010, 14:04 -
Vista CD burner issues.
By snakeyes in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 09:05 -
Dell I7 with vista gives black screen of death
By troyvcd1 in forum ComputerReplies: 9Last Post: 30th Apr 2009, 18:36 -
VirtualDub Appending Issues?? (Pix Inside)
By sandman423 in forum EditingReplies: 4Last Post: 7th Feb 2008, 06:01
