  1. I've typically used the 16X G05 or G04 Ridata DVD-r. somtimes they skip, but for the most part, I am pretty satisfied.
    Anyone know if Verbatums are better quality DVD-Rs?
    http://www.meritline.com/verbatim-dvd-blank-media.html
    Anyone recommend the 16X ones from the above link? There are like 8 different ones?
    Thanks!
  2. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Yes Verbatim are better quality. The different choices are based on how if at all you will print on the DVDs. Don't have a DVD printer go with the cheapest.
    Most of the people who post on this forum would always choose Verbatim over Ridata. So would I, if the price were equal, and the convenience were equal, or if the DVDs I burned skipped.
  3. I dont think they offer matte style?
  4. Can anyone help me with DVD-R 16X Verbatim recommendations above? I was looking at
    95203 ($32.99 for 100 pack)
    http://www.meritline.com/verbatim-16x-dvd-r-datalifeplus-shinysilver.html
    versus 95101 ($28.99 for 100 pack)
    http://www.meritline.com/verbatim-16x-dvd-r-media-branded-95101.html
