I currently have a Vista Home Premium connected to my TV using a DVI to HDMI cable. The picture quality is excellent, and I can't see myself going back to VGA. There is one problem that is really frustrating - if I change the input on my TV to something else (say, to play my Xbox), and then switch back to HDMI (my PC), the signal does not get picked up.
This also happened on my XP machine before it went belly up. Aside from restarting the machine or remoting in to my main machine with my laptop (which I can not seem to set up correctly in Vista), the screen display does not appear. Recently I have found that taking out the DVI cable and re-plugging it back in makes the picture appear on the screen, but this is not a practical solution.
Connecting my PC to the TV using DVI to VGA does not have this problem - I can switch to other inputs, turn the TV off and on, and still as soon as I select the VGA input on my TV, my computer display instantly appears. What is stopping my HDMI connection doing the same?
Thx in Advance!!
Try updating the drivers of your graphics card. Maybe there is a glitch somewhere.
I think I have had that symptom from time to time with my own dvi-hdmi cable. I'd end up rebooting or flat out turning it off to get it back. But I don't think I've had that problem recently.
By the way for your xbox did you start with component cables and then get the vga cable? I don't have a hdmi xbox so I started with component which was ok. But I finally bought a vga cable and set it to 1360x768 and was amazed at the differnce. Halo3 is lightyears better now - though my set is 1366x768 so I have to use the fill mode to get the last tiny bit filled.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Connecting LG Plasma via HDMI with PC - flicker problems
By TjS2011 in forum DVB / IPTVReplies: 19Last Post: 6th Dec 2011, 13:05 -
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 14:50 -
Connecting laptop to tv via hdmi
By hygieneboy in forum ComputerReplies: 11Last Post: 16th Feb 2009, 15:56 -
Problem connecting computer (DVI) to TV (HDMI)
By kizzad in forum DVB / IPTVReplies: 2Last Post: 14th Jan 2008, 21:52 -
Connecting the pc to tv via HDMI
By alintatoc in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2007, 13:48
