I've ripped a 45 minute VHS to Huffyuv with my SAA7113 capper. I'd like to bring it down to size with as little loss as possible, ideally ~2 GB. I'm not interested in burning it to a DVD that will be playable on a DVD player, I just want to free up a bit of HD space. X264 looks horrendous, and XviD has a good degree of wobble to it. I suppose H/X264 obviously wasn't meant for analog. What codec should I compress to? It's a rather ugly rip given the card I have and the fact that the VHS is 10+ years old.
wobble?
you've just kicked the most efficient and one of the most reliable codecs in one go.
why don't you provide a source sample,
and have someoe else have a go at it.
gl -
Your source is almost certainly interlaced. You'll want to inverse telecine or deinterlace to encode with X264 or Divx/Xvid.
If you have a film source, yes. Things like live sports and news are fully interlaced and will have to be deinterlaced instead.Originally Posted by galneon
Yes, MPEG2 will work if you use a player or MPEG2 decoder that deinterlaces or IVTCs on-the-fly. They usually don't do as good a job as a smart deinterlace/IVTC but they presumably will get better in the future.
can have interlaced xvid too...
i'm not into playing guessing games though with the user's actual problem.
No Huffyuv Codec under VirtualDub Compression
By Ryutso in forum Capturing and VCRReplies: 7Last Post: 28th Jan 2011, 03:31 -
Multithreaded/Multiproc/Multicore HuffyUV Codec
By Soopafresh in forum Video ConversionReplies: 0Last Post: 12th Jan 2009, 15:18 -
VDub - Frame Size Problem - Huffyuv-2.1.1
By cnolan011 in forum Capturing and VCRReplies: 8Last Post: 24th Oct 2008, 21:54 -
Magix videodeluxe plus 2007 and HUFFYUV codec
By PeterK in forum Video ConversionReplies: 3Last Post: 23rd May 2007, 14:18 -
Exporting to AVI, HuffYUV codec
By PeterK in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 09:21
