DVDR-3380 Latest Firmware upgrade Info
v3.12 (25th Apr 2006) - Original Shipped Version
v3.27 (23rd Feb 2007) - Fixes DivX6 issues + Freeze issues on disc update + trick mode T/C menu
Make sure the recorder is empty !!! You will need to press <0><0><0><9><OK> to find which version
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&sct=DVD_HARDDISK_R...=Link_Software
Download the four files then burn the files to a CD-R and follow the steps when you place it in the recorder
When you have finished the tray will be out don't panic just restart and all will be well.
N.B.> DO NOT POWER DOWN DURING THE UPDATE !!!!
Spideray
Here is the link to firmware update for DVDR 3380/55 LATAM (Lantin America model)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=PE&slg=ESP&cat=DVD_HOME_THEAT...=Link_Software -
I have a DVDR3380/78 (Lantin America model) with DVDR3380_LATAM_v03.26 45.04.05.10 firmware.
Can i use the EU version?
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 04:45 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 15:25 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 07:50 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 01:33
