I Have Downloaded A Series Via Torrent In DVD-Xvid Format And Now Trying To Burn To DVD But Having few Problems!!
The Series Consists of 10 Episodes In AVI Format All At 699MB.
I Tried Converting Them Using WINAVI Video Converter, 5 Episodes At A Time Thinking They Would Go Onto 2 DVDs, But The First Five Were Converted Onto 2 DVDs Alone, Even With The DVD Size Set to 4.7GB.
Is There An Easy Way Of Finding Out What The Final Size Would Be Without Converting Them, Or Is There A Way Of Getting All Of The Episodes On To One (4.7GB) Disk, Or 5 On One And 5 On The Other.
Will Accept Any Hard Or Easy Solutions!!!
Results 1 to 10 of 10
how much can go on a dvd is determined by bitrate and time. multiply them together and you get the filesize. use a bitrate calculator like this one,
http://dvd-hq.info/Calculator.html#Calculator
if they are hour long episodes, 2 is about all that will fit and still be watchable quality of over 3000kb/s.--
[s:f31c320e3b]So How Come I Only Get 3 Episodes To A DVD Whereas A Proper Copy Bought In The Shop Would Have up To 6 Episdoes On It? Same Series On Both.[/s:f31c320e3b]
[quote="aedipuss"]how much can go on a dvd is determined by bitrate and time.
So How Come I Only Get 3 Episodes To A DVD Whereas A Proper Copy Bought In The Shop Would Have up To 6 Episdoes On It? Same Series On Both. -
Easy way: buy a DIVX compatible standalone player. You can find them for $30-50 (or cheaper on e-bay). This way you burn as data disk, and there is no conversion, no quality loss. You can put 7 per disk this way (699MB x 7)
Slightly harder way: use convertxtodvd (trialware) or favc (freeware). These can convert & author to a DVD. You can compress probably 4 hours onto 1 DVD and still get mediocre quality, but the more you compress onto a disk, the lower the quality. These are easy to use and even create simple menus
There is no way that you will be able to get 10hours onto 1 DVD without horrible unwatchable quality. If you can stand crappy quality (but almost watchable), you might be able to squeeze 5 episodes per disk. -
1) Store bought DVD's are sometimes dual-layerOriginally Posted by kshillabeer
2) They are made from an original high quality source. Everytime you do a conversion, you lose quality. If you have an AVI episode that you downloaded, it has already has suffered at least some quality loss. If you convert this again to a DVD you will lose even more quality
=> go buy the DVD
if you don't care how bad it looks you can put as many as you like on one dvd. it still only depends on the bitrate you use encoding the mpeg-2. all 10 can "fit" if you squeeze them enough.
I've got a feeling that this ten-episode series is from Japan (or around there) and most likely not available for purchase in the UK...Originally Posted by guns1inger
Also, those 10/11-episode series are never subtitled by the originating studio and rely on fansubbers to provide the subtitles...
Just a reasonable guess.
Also, I'm guessing that the episodes are probably about 45 minutes long... So the most you want to put on a single single-layer disc is three episodes without an obvious degradation in picture quality, IMO... And that's if the original source is something like 704x396.Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
Subtitle help please - dvd episodes to xvid
By reakt in forum SubtitleReplies: 17Last Post: 9th Jul 2010, 00:14 -
How to convert DVD TV episodes to AVI Xvid or MP4 H264 with subtitles
By Baldrick in forum User guidesReplies: 9Last Post: 5th Jun 2010, 03:06 -
Problems with DVDFab when converting DVD TV episodes to Xvid
By ryangarfield in forum DVD RippingReplies: 3Last Post: 11th Oct 2009, 11:38 -
How to 'Ripit' to XVID with multiple Episodes
By DarkPhoenix77 in forum MacReplies: 4Last Post: 19th Sep 2009, 23:35 -
TV Episodes on DVD to Multiple MP4s w/ MeGUI - Help Please...
By alwayssummer in forum DVD RippingReplies: 1Last Post: 19th Jan 2008, 08:28
