I have an mkv file for which I would like to change the built-in audio track with a .wav file containing AC3 soundtrack. When I try to use mkvmerge to add the wav, I get the error "file identification failed for 'filename.wav'. Return code: 2. Error: The demultiplexer for the file 'filename.wav' failed to initialize: wav_reader: No data chunk was found."
I tried renaming wav but that didn't help. Any idea how to do this?
wav is from a different language version of the same video.
Are you usually supposed to be able to do this? Maybe the wav file was corrupt. I used virtualdub to extract it.
[The problem may be caused by virtualdub's saving process. I tried a different AC3 and it didn't have this problem]
[A solution is to import the video containing the wav instead of wav. Another way is to save the wav under a compliant program like delaycut]
How to find out muxing details from done mkv file?
By Bronta in forum Video ConversionReplies: 1Last Post: 16th Nov 2011, 04:21 -
DVD to MKV muxing audio and video?
By michaelb1878 in forum Video ConversionReplies: 1Last Post: 15th Apr 2010, 08:57 -
MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. Please
By rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 17:55 -
Muxing MKV file with mmg (mkvmerge)
By HAL4711 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 18:49 -
MKV Muxing Audio Out-of-Sync with Video
By Cube11 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2008, 13:27
