I had a movie broken up into two parts, each approximately 700 Mb. The PS3 had absolutely no problem streaming these from my media server. I wanted to combine them into 1 file though to simplify things. I used Virtualdub. Opened part one, moved to the end of the file, appended part 2, made sure video and audio were set to direct stream copy, saved it as a new AVI which ended up around 1.4 Gb (I've read the PS3 limit is 2 Gb?). Everything seemed fine to me. PS3 won't play the resulting file, says it's corrupted. I've tried this a few times now with other movies as well. Am I missing something? A step I should have done but didn't? Did Virtualdub change the files somehow? They do still play perfectly on my PC but the PS3 says they're corrupted. It's a bit frustrating. Any help at all would be greatly appreciated.
Thanks!!!!!
-Spaz
Hi Spaz.
I've been having the exact same problem. At first I thought it was the DivX codec but after using it with another video converter with same settings I soon realised the codec was not the cause of the problem. After mucking about for ages with virtualdub I found that saving the video as "old format avi" from the file menu the video worked without problems, whether it be streamed or on the ps3 itself. You can still reload the video with virtualdub, set the audio and video to direct stream copy and save it.
Hope that helps
Please don't take that as the be all and end all of your problem, I am by no means a encoding expert and come here regularly myself for help, I only registered to hopefully help someone with the same frustrating problem. With that in mind, do keep the original file just to be safe.
Chris -
Just for clarification, could anyone let me know of the difference between the "Save as avi" and "Save as old avi" in virtualdub
Cheers
Iphone 4 videos won't play on PS3
By BrianK in forum Video ConversionReplies: 2Last Post: 17th Aug 2010, 19:35 -
PS3 won't play audio from this burned AVI (specs included)
By bound4h in forum MacReplies: 5Last Post: 25th Jul 2010, 10:42 -
PS3 won't play audio from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 20:16 -
Some DVD+R won't play on PS3
By srobin in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 18:15 -
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22
