I have been using the tmpgenc dvd author 1.6 for some time now because it is easy and fairly flexible. I have a few avi's that have dts soundtrack and I would like to keep the dts as I prefer it to dd 5.1. Are there any authoring programs that will let you use dts for the soundtrack?
This is a very bad suggestion. DVD Maestro hasn't been made for many years. You'll have to find it through what I would call "alternate means of distribution" which would include Ebay and perhaps even P2P networks.Originally Posted by pcb
If you can afford it or have a way to get access to it through, ahem, "alternate means of distribution", Scenarist also supports DTS on DVD. Do note that according to DVD specs that DTS cannot be the only soundtrack on the DVD and comply with standards. Some authoring programs may allow you to do this anyway, but technically the specs require that either LPCM or AC3 audio also be on the discs in addition to DTS.
Blu-ray + DTS-HD authoring with tsMuxeR
By Zerrax in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2011, 19:30 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
TMPGEnc Authoring 4 DTS
By tommcd64 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Jun 2011, 17:32 -
Does this program support DTS?
By jackand7 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 13:39 -
Authoring a DVD with DTS 5.1 Audio
By wanguy2k in forum Authoring (DVD)Replies: 4Last Post: 12th Sep 2007, 18:52
