hi there, computer crashed the other day so i had to do a full restore, now when i play videos in vista media centre i get these black blotches on the white parts of the picture, ive tried fiddling with the codecs with no avail....any ideas?
Have you tried other software players to see if they exhibit the same problem? I would try VLC as it uses it's own codecs. If you still see the 'blotches', you might check your video card settings. I would also see if there is a newer driver for your video card.
What format is the video you are having problems with? Or is it all formats?
And welcome to our forums.
Open a video in two players at the same time. If one has the problem and the other is normal you have a video overlay problem. Go to the graphics card's setup applet and check the overlay settings, sometimes just called "video" settings.
ok, updated my drivers and eveythings fine, thanks guys xxx should have tried that first...what a goon
cheers
ryan
only black & white from S-Video
By Victor Hen in forum Newbie / General discussionsReplies: 11Last Post: 23rd Jul 2012, 21:40 -
Problem: Video Black and White in Samsung MM-DG25, How to change video outp
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jan 2011, 12:11 -
Connecting with s-video = black/white
By InthaHouse in forum Capturing and VCRReplies: 4Last Post: 10th Aug 2010, 03:13 -
video capture in black and white only
By oldboy29 in forum Capturing and VCRReplies: 8Last Post: 13th Jan 2008, 18:54 -
HELP, every video on my PC is Black and white ?
By shammi in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2007, 08:52
