I recently converted a bunch of mkv files to mp4 using GOTsent, handy little tool that. Unfortunately one of the files has about a second delay between the video and audio. I already dumped the mkv files so I'm not sure if it was due to GOTsent error or the source file was simply faulty, but regardless I have no idea how I could go about fixing the resulting mp4. Would appreciate any help, thanks!
Check the original file for errors. You may be able to correct the original file and perform the conversion again.
Otherwise (assumming the audio sync is a continuous offset from start to finish), you will need to demux the audio, add/remove audio from the beginning of the stream, and then remux.Google is your Friend
MP4 file out of sync in VLC, not in MPC-HC
By M3mbr4n3 in forum Software PlayingReplies: 17Last Post: 9th Feb 2013, 16:07 -
Audio out of sync on MP4 file
By adamf154 in forum AudioReplies: 3Last Post: 26th Feb 2010, 08:15 -
DVD to MP4 Audio Sync
By ee98vvt in forum DVD RippingReplies: 2Last Post: 5th Oct 2009, 15:04 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 22:28 -
i'm trying to convert a mpeg2 file to an mp4-audio is out of sync!
By cduval04 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2007, 17:56
