All of my dvd copies are on my hard drive. I would like to put them on some blank dvd's. Once they are on a dvd, would I need to use a program like DVDfab to burn them back to my hard drive (if I ever decided to do so)? Or can I just open the file once I put the dvd in, and copy/paste it (using something like teracopy)? Just trying to clear up some space on my hard drive.
You don't need any program. Just copy and paste the VIDEO_TS folder to your hard drive. Ripping is only needed for encypted discs and to eliminate region codes, neither of which a backup copy should have.
And jason, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
you decrypted them putting them on your hard drive they will stay that way burning to disc. dvdr is burned as data so copy/paste will work getting the folders off the dvdrs also. or just highlight and drag from folder to folder if you want.
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 09:14 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 17:18 -
Want to copy a DVD to external Hard Drive
By bwm258 in forum DVD RippingReplies: 9Last Post: 29th Jul 2009, 00:22 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32
