Dear friend.
I don't know where to post my topic so I post it here,hoping that it is the right place.
I have a video file such as .avi or .wmv file.
I have two sub for this file.One sub is English and the other is Vietnamese.Both of sub are correct.That mean it is time correct and display correctly.
Now.How can I burn a standard DVD with these 3 file (1 video and two sub file)
If I have another there file (One other Video file and two other sub file).Can I put these two film into a standard DVD.
Thanks for reply.
ConvertXToDVD, resize for overscan, import subs (I think).
After trying ConvertXtoDVD i found that.This tool reduce the audio quality of my video file.After convert my video size is only 2.1 instead of 5.1 as before.Do i have to set something.
Thanks. -
2.1 instead of 5.1 what ? What are you measuring ?
Also, what is your source ? Resolution, bitrate etc ?
ConvertXtoDVD will keep 5.1 AC3 audio, but will convert anything else to 2 channel AC3 at 192 kbps.
You could try DVD Flik or FAVC, which have better overscan handling.Read my blog here.
dvdshrink, always found it to do the job & if you ever want to convert from avi to dvd nero vision express is good.
How to burn HD movie files (.m2ts, .mp4, .mkv) to standard DVD
By neworldman in forum DVD RippingReplies: 4Last Post: 17th May 2010, 12:01 -
Burn Standard Definition to Blu-Ray? -4 archive
By markqc in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Jan 2010, 11:02 -
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 22:29 -
Shot in HD - burn to standard DVD
By revlis in forum Video ConversionReplies: 1Last Post: 6th May 2008, 22:56 -
Burn standard DVD project to Blu Ray disc?
By whoisquilty in forum Authoring (DVD)Replies: 12Last Post: 24th Feb 2008, 15:21
