Hi,
I would like to convert a H264 MKV file to uncompressed RGB AVI. I have looked at using VirtualDubMod, but it wants a "VFW" (Video For Windows) codec instead of a DirectShow codec in order to do this. Anyone know where I can find one that will work?
Otherwise, does anyone know a program which will do this conversion with it's own codecs instead of looking at the one windows uses at the moment.
Thanks,
ta2
which won't actually work unless it was encoded with vfw avc.
use avisynth with directshowsource()
http://avisynth.org/mediawiki/DirectShowSource
howto play Uncompressed RGB (AVI)
By kamaldeepdung in forum Video ConversionReplies: 33Last Post: 7th Jan 2012, 17:19 -
Uncompressed AVI to Quicktime H264
By Simmons in forum Video ConversionReplies: 7Last Post: 3rd Aug 2011, 20:15 -
Uncompressed 24bits RGB AVI - how to convert
By mooplesdooples in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 22:08 -
h264 avi to mkv
By frostiex in forum Video ConversionReplies: 1Last Post: 27th Feb 2009, 09:45 -
MKV to Uncompressed AVI
By TheLarch in forum Video ConversionReplies: 3Last Post: 15th Apr 2008, 09:11
