Hello all!
I need a bit of help with my AviSynth script I guess. The thing is I'm trying to insert some subtitles in my source video and the source video is a little weird; It's a WMV9 in an .avi container @ 119,88fps. Now this is the script that I use:
And when I load this script in TMPGEnc, I get this error:Code:LoadPlugin("DGDecode.dll") AVISource("C:\file\file.avi") ChangeFPS(23.976) LoadPlugin("VSFilter.dll") TextSub ("subs.ass")
What's wrong here? By the looks of it the codec is missing, but the video plays normally when I simply play it in BSPlayer (or any player for that matter) and I can also edit the video using TMPGEnc normally if I don't use AviSynth. Then just to be sure it's not a codec problem I started G-Spot and looked at the video codec there and it said codecs installed.Code:AVISource: couldn't locate a decompressor for fourcc WMV3
Please help!
Two possibilities:
1) Install the "WMV9 Video Compression Manager"
(I suppose AVISource requires it for opening wmv-in-avi);
2) Try DirectShowSource instead of AVISource;
HTH.
P.S.:Code:LoadPlugin("DGDecode.dll")
Thank you! Installing the WMV9 VCM did it! Well at least I thing it did it. I'm going to try to encode the video right now
Thank you for your help!
As for the plugin; this script was provided by some guy working in a fansub group so I really don't know what the plugins are all for but heres the explanation I found;
DGDecode is today's fastest way to frameserve MPEG-1/2 video to any video encoder via AviSynth. DGDecode and AviSynth 2.x allow the video to stay in the video's native colorspace, so you won't incurr quality loss and speed loss due to unnecessary conversions (unlike VFAPI, which converts everything to RGB and the encoder coverts it back to YV12). -
Yes, but you aren't trying to open an MPEG-1/2 video. This particular script doesn't need it, although it doesn't do any harm.
DGIndex says 100% Video, but MeGUI Avisynth analysis says Source Type Film
By Simcut in forum DVD RippingReplies: 11Last Post: 9th Mar 2012, 17:10 -
Avisynth source loading?
By yugurya in forum EditingReplies: 5Last Post: 22nd Jan 2012, 14:57 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 14:15 -
720p or 1080p Source? For converting to WMV-HD
By Mickey79 in forum Video ConversionReplies: 19Last Post: 28th Jan 2008, 15:03 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48
