Hi all!
Just wanted to know if anybody knows how to convert fps in any software.
The thing is I have a source of 120fps and I want to add subtitles (.ass) and convert the 120fps to 30fps (or any other). I tryed using AutoMKV, but it does nothing when I choose convert the fps, and I tryed TMPGEnc but this software supports only videos with 60fps maximum. VirtualDub does not do any better in this matter.
Any ideas?
AviSynth:
SelectEvery(4,0)
or:
ChangeFPS(29.97)
both of which tell you to keep only one of every 4 frames. Or, if using the TIVTC filter:
TDecimate(Mode=1,Cycle=4,CycleR=3)
which tells you to remove 3 duplicate frames out of every 4 frames. If you're going to mess with anime raws, you'd best learn some AviSynth. And, of course, there's a good chance the correct framerate isn't 29.97fps, but 23.976fps, or is a hybrid with both framerates in the episodes. -
Where would one get 120 fps source?
For NTSC rates:
120 Hz HDTV sets either replicate 5 x 23.976 = 119.880 sometimes with intermediate interpolated frames,
or 29.97 fps is replicated 4 x 29.97 = 119.880 sometimes with intermediate interpolated frames,
or 59.94 fps is replicated 2 x 59.94 = 119.880.
For PAL rates
120 Hz HDTV sets replicate 5 x 25 = 125 sometimes with intermediate interpolated frames,
or 5 x 24 = 120 fps sometimes with intermediate interpolated frames.
Nobody broadcasts 120 fps.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
A lot of anime is a mix of 29.97 fps interlaced, 29.97 fps progressive, and 23.976 fps progressive sources. These are often converted to ~120 fps (least common multiple) for P2P.Originally Posted by edDV
Interesting. That results in very large files.Originally Posted by jagaboRecommends: Kiva.org - Loans that change lives.
Not really, most of the frames are exact duplicates so they don't take much bitrate.Originally Posted by edDV
Getting 120fps to render in slo-mo
By simonov in forum EditingReplies: 4Last Post: 16th Dec 2011, 22:08 -
Converting a 60fps .MTS video to a 30fps raw .AVI?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 16:57 -
Converting 720p/60fps file to 30fps?
By mt123 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 13:34 -
Converting 30fps Progressive to 25fps interlaced ? (Avisynth & VDub)
By blewyn in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 18:51 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24
