I've been backing up my DVD collection thanks to this website, and I was wondering about VHS. I have quite a few VHS tapes that are not on DVD, or too expensive to track down. I want to copy them to DVD. I also want closed captions to remain intact too if possible. I've got Pinnacle software and a capture device. I'm not doing anything illegal since I am only converting stuff I own just like my DVDs. I'd appreciate your help. Thank You.
	You usually have to rip your CCs from a separate pass through your capture card using something like Graphedit and the correct filter setup (search the forum). Also, your capture card has to PASS the CCs to the computer - quite a lot of them do NOT.
 Once captured, you can convert them to a form that a DVD authoring program can use, so once you are ready to author a DVD, simply import your CCs and go.ICBM target coordinates:
 26° 14' 10.16"N -- 80° 16' 0.91"W
	I don't understand you want copy vhs to dvd , fine.Not an easy task (especially with pinnacle products) but feasable none the less.
 Then you talk about closed captions "i want them to remain intact".To the best of my knowledge, vhs tapes don't have closed captions, UNLESS there are directly put within the pictures which wouldn't be a matter if so.
 So i'm kinda lost
	Your knowledge isn't up to par. VHS tapes routinely contained closed captions.Originally Posted by themaster1ICBM target coordinates:
	As SLK001 already said, VHS tape *do* have closed captions stored on them. Even if I record something from TV, the CC data is there. BTW, CC is also on Laserdiscs.
 Darryl
  How to rip closed captions from a DVD?By hanyj in forum SubtitleReplies: 36Last Post: 13th Aug 2023, 12:02
  DVD player with closed captionsBy rrrr in forum SubtitleReplies: 22Last Post: 6th Apr 2011, 12:51
  closed captions and dvr/dvdBy mosk3609 in forum DVD & Blu-ray RecordersReplies: 30Last Post: 23rd Jun 2008, 23:53
  Closed captions not working on DVDBy pualzennon in forum DVD & Blu-ray RecordersReplies: 10Last Post: 20th Oct 2007, 15:27
  DVD to mpeg2 with closed captionsBy EyeI3all in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 10:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
