I am going to reauthor a DVD for a friend. It is a 3 minute product presentation. It will have no menu and needs to loop and replay over and over. Is this looping function something that is set in the player or is it an attribute that needs to be set when the disc is authored?
Set on the disc.
What program? Some have a specific "loop" function, others require a pretty basic trick involving the playlist. I have to make these often, for kiosks and demo displays.Want my help? Ask here! (not via PM!)
Thanks. That is what this disc will be used for - a kiosk. I use DVD Lab Pro. I'll take a look at it this evening. I seem to remember this function but I have never needed to use it before.
I found this guide which uses PgcEdit. I've not used it, so I don't know how accurate it is. http://www.tarnsyke.com/Geoff/Guides/Looping_Video.pdf
-The Mang -
I assume that you mean in the Navigation view to just drag a line from the VTS output back around to the input?Originally Posted by Midzuki
Ulead DVD Factory has an option "auto repeat when playback end", and remember to check off "create menu". It's cheap when you buy "old" or "used" version
How to Stop Blu-ray Menu Theme Song Looping
By c627627 in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Nov 2010, 22:20 -
Dvd with looping chapters...
By miksterr in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2010, 00:23 -
Creating a continuous looping DVD playlist from hard drive
By bryners in forum Software PlayingReplies: 4Last Post: 6th Apr 2010, 14:49 -
looping video for menu
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 23rd May 2009, 07:03 -
Specific looping?
By Koron in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2008, 16:32
