I have a TDK DVD RW880N burner bought around 2004 and have used Maxell DVD-Rx4 using Toast 6.1.1. Lately I'm running out of DVD so I bought Maxell DVD-R brand again with 16X max and somehow it's indicating error message "Interface error -50 the connection is not stable." I Rebooted the computer but still giving me the same error. If I used my old Maxell x4 I don't have any problems at all. What's going on?
dvd burners have an internal lookup table in the firmware to tell it how to burn different media. your drive is so old it can't burn current blanks is my thought. if your mac can handle a drive upgrade it's time. current 20x burners can be bought for under $30. if not maybe it's time for a pc.
The 880N is an 8x burner. Do your 16x discs allow burning at 8x speed?
Have you ever upgraded the firmware since you bought it? To some extend, a newer firmware may support newer media. The latest TDK 1.37 firmware updater (Windows program for DVD±R/±RW Writer 8x) has a file date of October 1, 2007. -
It indicated that this disc may be recorded with 1x - 16 x and TDK allows speed selection and I even selected 4x but still same error message. Is there a website that let's me upgrade my firmware since the link you gave me only works with window. Thanks.
Sadly, many drive firmware upgrades need to be applied with a PC. So, if updated firmware exists for your drive (and you need to verify this), and no Mac-compatible update utility is provided by the manufacturer, then your only option is to find a windows box, put your drive in it, and update it there.
Colossal pain, yes, but considering the options (hunt for other compatible media, buy a new drive), maybe not so bad... -
Dump that old burner. You can buy one of the new Lite-On units for about $40.
I lost my cd with the drivers on it. Does anyone know a link where I can get them. Any help would be appreciated.Originally Posted by rumplestiltskin
I lost my cd with the drivers for my TDK 880n when I moved into my new place. Does anyone know of a link where I can get these drivers?? Any help would be appreciated.
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 03:18 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 15:53 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 21:41
