Hi all, firstly am glad to have found this site as it appears to have lots n lots of useful and helpful info.
I came across this site after i had a problem burning some files to a dvd.
I have an ISO file on my pc (Fitness video) and when i open it up it has:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01.0.IFO
VTS_01.0.VOB
VTS_01.1.VOB
VTS_01.2.VOB
VTS_01.3.VOB
VTS_01.4.VOB
Now this is a dvd which has menus which are linked to different parts of the dvd. I am totally confused of how to burn this onto a dvd to use on my dvd player.
Anyone please help, im only used to straight burning avi's onto dvds
Im on a mac and use roxio toast to do my usual burning
Many thanks to anyone who can help me out!
Results 1 to 9 of 9
You should be able to play the ISO of the DVD with VLC player to see if the DVD structure is working. If so, you just need to use a Mac ISO burning program to burn the DVD. Since this is a Mac question, probably better in our Mac Forum. Moving you.
And welcome to our forums.
sufcdan, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
make a folder with the following name:
VIDEO_TS
throw all those files into that folder and drag it onto the apple video player to check and see that it will play fine... -
Ummm.... re-read the original post... if they have an ISO, obviously they already have a VIDEO_TS & AUDIO_TS folder contained within the ISO and in order to "throw" all those files into a new VIDEO_TS folder they would have to extract all those files from the ISOOriginally Posted by pixel zombie
I seriously doubt someone made an ISO without either of those folders and just containing the dvd files....
Do what redwudz said, most likely, just burning this ISO to dvdr with whatever program MAC user's use to burn ISO/Image files to dvdr will result in a perfectly fine and playing dvd.
8) -
i re-read it, he makes no mention of going into a 2nd folder and i have downloaded ISO files that had that very same problem...
I'm just gonna walk away from this now before i get my @$$ banned
If this ISO file is a ready-to-burn disk image, then go to Toast's Copy tab, use the Image File option, select your file and burn.Originally Posted by sufcdan
I presume VTS_01_0.VOB, as VOB files should have two underscores and one dot.Originally Posted by sufcdan
If burning directly from the image file doesn't work, then you could create a copy of the correct folder structure on your hard disk. The folder structure should be like so:
Go to Toast's Video tab, select the VIDEO_TS Folder option, drop the VIDEO_TS folder on the Toast window and burn. -
I'm surprised that no one has suggested that you mount the ISO with either OS X's disc image mounter or Toast and see if DVD Player will play it. DVD Player is a lot fussier than VLC so if it plays it then you can be 99% sure that it's a kosher image and you can just burn with Toast's Copy->Image File option.
You can use Disk Utility or my own droplet to burn an ISO or IMG file to DVD.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Burning ISO file to DVD
By hcs in forum DVD RippingReplies: 5Last Post: 2nd Feb 2008, 13:34 -
dvd iso/files burning problems
By CommanderZero in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 01:25 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
