    Jan 2008
    Belgium
    hy
    i want to put my movie on a 4gb memory stick and my movie is a few mb to big how can i simply compress my mpeg file to make it fit?
    USA
    You can use a bitrate calculator like the VideoHelp Bitrate calculator. Set a custom size, say 3800MB, and the running time of your video. Plug that bitrate into a MPEG encoder and re-encode your file.
    Or if it's just a bit over in size, try ReJiig. It works similar to DVD Shrink, except for MPEG files. It 'transcodes' like Shrink, so it's generally faster than a full re-encode.
    Jan 2008
    Belgium
    thanks it works very good with dvd shrink
    Jan 2008
    Belgium
    when i compress the vob files from 39.99gig to 39.7 and then convert it to 1big mpg file the screen is chaking whole the time
    Jan 2008
    Belgium
    but before i convert them with vob2mpg it doesn't chake
