  1. Member coody's Avatar
    Jan 2005
    Audiovox 10” portable DVD (PVS33116) does not have a remote control but cheap. Is it hackable for region free?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Specialty players are usually not "hackable" and the typical way for users to "hack" a player is via remote code. So two strikes against that player.
    If you know that you want/need a region free player, then get a player that supports region free. Don't take chances on "hacking" a player later.
    Google is your Friend
  3. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    The ability to hack region codes is a result of the manufacturer's selling the same unit in many areas of the world. Rather than make a separate model for each region, they produce the same hardware and change the region code. Methods include the menu hacks which use a remote, switches or jumpers on the circuit board or different firmware.
    If your model is distributed worldwide there is probably a way to hack it, but it may not be easy or documented or possible without a firmware update.
    If you can't find any documentation on how to hack it and are not a technical whiz, assume it can't be hacked.
  4. Banned
    Freedonia
    Note that many portable players CANNOT be hacked by any means, not even with a remote control. A quick search I did on Yahoo about this did not look very good for this player.
