Hi!
I'm a member of the FFmpegX's french forum (carpo).
We can't find a solution to this problem :
Here's the log:
Encoding started on Wed Feb 13 15:20:05 CET 2008
MEncoder dev-CVS-051126-18:35-3.3 Coffee 2000-2005 MPlayer Team
parse error at line 1
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
Exiting... (configfile error)
Option ` needs a parameter at line 2
parse error at line 5
Option a needs a parameter at line 7
Option , needs a parameter at line 8
parse error at line 9
parse error at line 10
parse error at line 11
parse error at line 12
parse error at line 13
Option 0 needs a parameter at line 14
parse error at line 15
Option h needs a parameter at line 16
parse error at line 17
parse error at line 18
Option 1 needs a parameter at line 19
too many errors
The guy wants to insert subtitles in a video...
Thanks for your help!
Edoud
iBook G4 1Ghz
The mencoder binary has the linesOriginally Posted by edoud
directly following each other. If this line "parse error at line 1" somehow came between it, then the binary wasn't installed correctly. When he is just running mencoder, it already gives errors, even before it looks at any file.Code:MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team Mac OSX static build for ffmpegX
jim.eye should log in with an administrator account, download a fresh copy from the URL mentioned in the Installer window, unzip that on his desktop, use the Locate buttons for mplayer and mencoder, set the appropriate checkboxes, let the installer copy them to the right location, then trash the originals on his desktop.
How to insert NON-PERMANENT subtitles to a DVD?
By CrisLark in forum SubtitleReplies: 2Last Post: 9th May 2009, 14:27 -
how to insert subtitles....thx from spain
By xaviereb in forum ffmpegX general discussionReplies: 1Last Post: 22nd Nov 2008, 09:57 -
How do I insert subtitles into a video?
By AORMan in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2008, 05:32 -
How do I insert chapters into a VOB file with subtitles?? URGENT!
By wozo in forum Authoring (DVD)Replies: 11Last Post: 30th Mar 2008, 19:47 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 11:00
