I need to create a font/typeface with only squares. Alternatively, download one, if there is one for free.
I know that "windings" probably has some symbol that is just a square, but this needs to be the square on all letters of the alphabet....
Think like this: if i type the word "videodrome", and i do it in two layers with a normal Times New Roman font on top, and my square-font underneath, the result should be the text "videodrome" with a black "bar" or "box" underneath. More or less following the character width, neatly.
Any ideas on what could be the best program to achieve this? I need to create a Truetype font, alternatively one of those PFB/PFM fonts.
peace
You need a font editor.
http://cg.scs.carleton.ca/~luc/fonts.html
http://cg.scs.carleton.ca/~luc/editors.html -
Yeah, thanks....
i downloaded Fontlabs "Typetool 3", a demo... I'm starting to realize though, that i'm not gonna be able to pull this off like that.
If i want to make the font, within reasonable time i'd need some powerful snapping. And i would load verdana.ttf , and just doubleclick each letter, and, swisch, draw a square to cover the whole letter. And then continue to the next letter and draw a square in the exact same height.
I couldnt get the snapping to work very well in TypeTool though.
Its interesting by the way that people seem to see it as an outdatd tool, it feels very mature. I guess Fontographer and the others must be very complex. -
"Complex is a point-of-view."I guess Fontographer and the others must be very complex.
[ Palpatine to Anakin --- "Star Wars III" ]
1) Have you learned the diffrence between fixed-width and variable-width?If i want to make the font, within reasonable time i'd need some powerful snapping. And i would load verdana.ttf , and just doubleclick each letter, and, swisch, draw a square to cover the whole letter. And then continue to the next letter and draw a square in the exact same height.
2) Have you ever heard about "copy and paste"
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 14:52 -
bigger and better font when I create AVI with mencoder
By Cazz in forum DVD RippingReplies: 0Last Post: 16th Mar 2010, 18:17 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 20:59
