I have a Sony SLV-100 DVD/VCR combo player and a Sony DRU830A burner in my PC. This has plagued me for as long as I have been burning DVD's. The player is not supposed to be compatible with DVD+R's, but yet I just had a 50 pack of TDK's and they worked great. Now for some reason I ended up with some Sony DVD+R's. They won't play on the player mentioned above. Also the last TDK did not play either.
I had some Phillips DVD-R's would not play. I am going crazy here just trying to find some decent blank media that will play consistently in this palyer, not hit and miss. Probably the dilema for everyone right... Oh by the way they all play back on my PC, but I also have a bargain brand (Colby) DVD player and my sons XBox and they don't play in there either. My son has a Phillips burner in his PC I am going to try to burn this Sony media there and see what happens. I am also going to pick up some TDK or Maxell DVD-R's. I am just trying to rule out my burner, which I have read is pretty good. It has to be the media. I also heard the Sony Players are very picky too. Are there any preferred players that don't have these issues? Your comments are greatly appreciated.
Closed Thread
Around here we generally recommend Taiyo Yuden (you'll have to mail order it) or Verbatim. Other brands these days are rarely made by the best manufacturers. TDK and Sony used to be good, but these days they are often crap, made by third rate manufacturers. I wouldn't touch any of the brands you mention.
Philips DVD players are rarely fussy about media. Any decent recently made DVD player shouldn't care about DVD+/-R and should play both with no problems. DVD+/-RW support was poor on older models, but with modern DVD players, both should be supported. Finally, my limited experience if you want to deal with DL media is to only use DVD+R DL as DVD-R DL seems to be problematic for some players.
Try using either Verbatim or Taiyo Yuden DVD+R discs and hopefully you'll be OK. You might be interested in looking at this site about DVD media quality:
http://www.nomorecoasters.com
Good sources for Taiyo Yuden are newegg.com, rima.com and supermediastore.com.
aruba92, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/topic346508.html#1816260
Moderator redwudz
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 18:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 14:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 11:30
