    Feb 2008
    Belgium
    Hi,
    I have a weird problem with suprip.
    I m trying to convert sup subtitles into srt. Some of he subtitles I converted without problems, but for others I keep getting an exception error, with the following description (sorry it's in French) :
    I tried on 5 different computers, on Xp or Vista...
    Would anyone have any idea ?
    System.Exception: Tentative de division par zéro.
    à SupRip.SubtitleLetter.ComputeAbsDiff(Byte[,] a, Byte[,] b)
    à SupRip.SubtitleLetter.Matches(SubtitleLetter o)
    à SupRip.SubtitleFont.FindMatch(SubtitleLetter l, Int32 tolerance)
    à SupRip.MainForm.ImageOCR(SubtitleImage si, Boolean reportUnknownCharacter)
    à SupRip.MainForm.LoadSubtitleImage(Int32 number)
    à SupRip.MainForm.LoadSubtitleFile(String fileName)
    à SupRip.MainForm.loadButton_Click(Object sender, EventArgs e)
    à System.Windows.Forms.Control.OnClick(EventArgs e)
    à System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    à System.Windows.Forms.Control.WndProc(Message& m)
    à System.Windows.Forms.ButtonBase.WndProc(Message& m)
    à System.Windows.Forms.Button.WndProc(Message& m)
    à System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assemblys chargés **************
    mscorlib
    Version de l'assembly : 2.0.0.0
    Version Win32 : 2.0.50727.312 (rtmLHS.050727-3100)
    CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
    SupRip
    Version de l'assembly : 1.0.0.0
    Version Win32 : 1.0.0.0
    CodeBase : file:///C:/Users/Tof/Desktop/BD%20rip/SupRip.exe
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    mscorlib.resources
    System.Windows.Forms.resources
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Débogage JIT **************
    Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
    application ou cet ordinateur (machine.config) doit avoir la valeur
    jitDebugging définie dans la section system.windows.forms.
    L'application doit également être compilée avec le débogage
    activé.
    Par exemple :
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I can't read that, but if the software is working on some files and not others, then I suspect something is different/unsupported in the files that don't work.
    Google is your Friend
    Feb 2008
    Belgium
    it is indeed but I have absoluetly no idea what's wrong...
    Thanks anyway...
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could always try a different subtitle tool. There should be several in the Tools section.
