Hello all,
I have an avi clip just over five minutes long. I'd like to add unicode subtitles, similar to the Ethiopic characters you find at:
http://www.amharicdictionary.com
I don't mind if the subtitles are 'burned in' to the video - it's a quick and dirty job I'm doing.
I tried Ulead VideoStudio 11, but pasting the characters gives gibberish, and I can't type in it using Tavultesoft Keyman, my method of entry.
Any suggestions for an easy way to add such subtitles?
Thanks.
You can use VSFilter + VirtualDub to get permanent subtitles,
or MaestroSBT to produce DVD-compliant subtitle pics from .SSA files.
Search this forum with some more attention and you will find
more details about non-ASCII subtitles.
P.S.: I'd like to say a big fat <ROT-13>SHPX BSS NAQ QVR!</ROT-13>
to all webdesigners who like to believe their pseudo~UTF-8/Unicode HTML files
are 100%~OK only because the non~W3C-compliant wannabe browser
is able to display them correctly.
Thanks for the reply.
But I need to make .ssa files, and I've tried a couple of tools that claim to work with unicode, but I've been unable to get them to work with the characters I am using.
How to Add Text Effects and Unicode Characters to MPEG-4 Subtitles
By PBear in forum User guidesReplies: 9Last Post: 20th Sep 2012, 09:15 -
How can I force my Video Converter to read Unicode UTF-8 subtitles?
By MoneyHoney in forum SubtitleReplies: 7Last Post: 27th Apr 2012, 19:13 -
Able to show Unicode subtitles on DVD at all?
By michcio in forum SubtitleReplies: 0Last Post: 6th May 2009, 21:05 -
Foregin subtitles UniCode (SubRip & mkvmerge)
By ronnlund in forum SubtitleReplies: 0Last Post: 9th Sep 2008, 04:19 -
Home DVD Player that supports arabic (Unicode) subtitles
By waza in forum SubtitleReplies: 0Last Post: 7th Sep 2007, 18:28
