Which is better for use in home theater bitstream out or PCM out from my set top player?
The player is hooked up to a Yamaha 6.1 amp.
Thanks.
--dES
"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
You aren't likely to tell any difference. It mostly boils down to what your receiver supports.
Google is your Friend -
If you are using an optical digital cable then use "Bitstream",
"Pcm" is stereo only, -
Bitstream for AC3 or DTS
PCM for stereo onlyRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks all.
I use the optical out to the amp.
I will set the player to Bitstream.
I appreciate the info.
--dES"You can observe a lot by watching." - Yogi Bera
Audio DVD player question
By Abas-Avara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Aug 2009, 15:42 -
Is there any DVD Player with FireWire output? (no recorder)
By Sean_ve99 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 4th Jun 2009, 13:58 -
sound output of 1 DVD player to another
By Shikhar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 27th Dec 2008, 23:50 -
question about getting English audio track in DVD player settings
By jimdagys in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Nov 2007, 09:05 -
VCR/DVD player with S-Video output
By arturo83 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th May 2007, 02:14
