what is the quickest and easiest to find out what the mpg is...352x240, ntsc-pal (352x288) etc...I used to be able to right click and go to properties-details, but after i upgraded media player it stopped i think..
running win2k Pro
As far as I know, you can't get much detail on your mpeg file by right clicking. It works for avi files, not mpeg files. If you want more info on mpeg files, you can use V-Dub ( works for mpeg-1 only). Or you can get
Bitrate Viewer from www.tecoltd.com/bitratev.htm. You get more info than you care to know with it. -
Sweet, just hat I was lookin for! I think your right...it was only on AVI files that would give you the detailed info in the properties-details tab...now I usually DL MPG, no more conversion crap!
The Bitrate Viewer is unavailable at www.tecoltd.com/bitratev.htm.
What else can be used to do the same and where can it be obtained?
The link he published has a period at the end, it's the only problem. Try this:
http://www.tecoltd.com/bitratev.htm.
- Dug -
Getting to the site is not my problem - the file seams to be unavailable - I keep getting file not found errors!
Anyone help please?
Use TMPGenc --> MPEGTools ---> TAB Demultiplex
Open the MPG file (no matter MPEG1 or MPEG2) It almost immediatly tels you;
MPEG1 or MPEG2
Bitrate Video
Frames per second
Resolution
Audio Sampling Rate
Audio Bitrate
Easy as can be. IMHO it's even better then Bitrate ViewerThere R 3 sides on every story;
Yours, Mine and the truth
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 14:13 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04 -
Easiest way to join several MP4 files?
By slateef in forum EditingReplies: 1Last Post: 20th Sep 2008, 23:44 -
Newber: easiest solution 2 convert dvd (aud/vid .ts) from HD to NAS in MPG
By gizfs in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 19:27 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 22:42
