My understanding is that an HDMI cable carries both the audio and video signals. That is, I only need the one cable if I am going to hook a dvd player to my tv.
I do have this setup in my bedroom on my 23" Samsung with a Sony upconvert dvd player. I will be purchasing a 40" 1080P HDTV this weekend, and my newly purchased blu-ray player does not mention the option of just using the HDMI cable with the tv. I am assuming I can do this, but I would appreciate any input that goes against this option.
I have no home theatre system as of yet and I know I will be sacrificing surround-sound.
TIA
TANSTAAFL
Yes, video and audio. From our Glossary:
HDMI
HDMI (High-Definition Multimedia Interface) is the first industry-supported, uncompressed, all-digital audio/video interface. HDMI provides an interface between any audio/video source, such as a set-top box, DVD player, and A/V receiver and an audio and/or video monitor, such as a digital television (DTV).
HDMI supports standard, enhanced, or high-definition video, plus multi-channel digital audio on a single cable. It transmits all ATSC HDTV standards and supports 8-channel digital audio, with bandwidth to spare to accommodate future enhancements and requirements.
http://www.hdmi.org/faq/faq.asp -
It's more than likely that your HDTV and Blu-Ray player have the HDMI connections, so there's no need to worry.
If you're still having any anxiety, check the specs on your HDTV and player at the manufacturer's website... They typically have the user manuals online for viewing and/or download.
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
HDMI Wall Plate>>Quality?----HDMI over Cat5E/Cat6????
By cpeters12 in forum DVB / IPTVReplies: 5Last Post: 28th Jan 2011, 03:27 -
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 13:50 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40
