    Mar 2004
    Wheeling, WV
    I am trying to convert a .mkv file to a .avi file and I am using AlltoAvi to do it. The problem is that since I started adding the subtitle option, the conversions crashes about half way through the process. Why is this happening? It wasn't doing it without the subtitles.
    Here are the settings I am using:
    Screen size: 704-400 Bi Cubic
    Video Encoder: XVID
    Video Bitrate: High Quality
    Audio Bitrate: High Quality
    Subtitle: 1 English
    Thanks everybody see if anybody knows the answer...
    Jun 2005
    Portugal
    convert to AVI without subtitles, and then add subtitles to the AVI
    Mar 2004
    Wheeling, WV
    How do I do that?
    Jun 2005
    Portugal
    I don't know that tool, but since you said that the error came because of adding subtitles, then the obvious is not to add subtitles.....you can make that in a later stage using Vdub (for example)
    Mar 2004
    Wheeling, WV
    Ok, but do the subtitles get added by hand in VDUB or does VDUB just add the entire subtitle track?
    Jun 2005
    Portugal
    you must reencode, but this seems to be better :
    http://www.calcitapp.com/AVIAddXSubs.php
