Please help
I am converting divx film to vcd. I always use virtudub to extract the sound to 44100 and then use TMPGEnc I load the correct template for the frame rate. The problem is when I watch the film back the movie always starts ok then during the movie the sound goes out of sync and then corrects itself it does this say 3 times during the average movie.Then on other occasions the movie will run for 20min ok the go out of sync. Please help as i have tried everthing and would be greatfull with a response.
Ps I am not spliting the movie.
dont extract the audio.. I converted numerous divxs to vcds and have no sound issues.. raise your direct x settings in tmpgenc until it will open and use the audio in the divx
good luck! -
Thanks jasond for replying to my message one question where is the directx setting in tmpgenc looked under enviormental settings but can't see it could u help.
Thanks derek -
Sure.. Im at work and dont have it here..but under enviro go to vfapi then raise the direct show to +1 (anything higher causes playback probs with existing files)
I will reply with more details tonight if you still need help
Good luck
TV RIP is there something wrong?
By JackDanielZ in forum Video ConversionReplies: 3Last Post: 22nd Apr 2012, 12:35 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
What is wrong with this picture?
By anonjon in forum RestorationReplies: 20Last Post: 10th Sep 2007, 13:02 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
