Hi there guys,
Recently i have acquired a Sony HDR-HC7 camera - and a PC - HP Pavilion M9060N - which has HDMI port. Also the camera has a HDMI port.
Now my problem is that every time i connect the camera thru that port - the PC wont recognize it - actually nothing happens - but as soon as i put the FireWire cable everything is normal, and i can capture.
Anyone can tell me what i do wrong here ?
(I thought that HDMI will work as the FireWire - just plug and play) it seems that there must be some other settings to be made.
What are the main differences between HDMI and FireWire capturing ? (in the matter of quality)
Thank you in advance for those taking their times to answer my questions.
respect,
soreen
To cut, or not to cut ... who is the splitter ?
The HP M9060N has no ability to capture over the HDMI port. The port is for output to a monitor only. Same goes for the HDMI port on your camcorder. It is for output only.Originally Posted by Soreen
Bidirectional DV/HDV transfer is done over the IEEE-1394 port. The camera transfers as 720x576i DV format or 1440x1080i HDV format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thank you for the info. Appreciated.
Capturing HD videos using HDMI or Usb cable
By jojoralte in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2012, 22:33 -
Capturing HDMI output
By Andrroid in forum Capturing and VCRReplies: 7Last Post: 6th Aug 2011, 01:34 -
Capturing HD From Another Computer's HDMI Out
By brandondrury in forum Capturing and VCRReplies: 20Last Post: 15th Mar 2011, 14:52 -
Capturing from HDMI
By koberulz in forum DVB / IPTVReplies: 2Last Post: 14th Dec 2008, 07:42 -
XBOX360 PS3 - HDMI Full HD Capturing
By TermiATT in forum Capturing and VCRReplies: 6Last Post: 12th Jul 2008, 21:59
