got 4x LG (forgot the modle) DVD burner and it can't read any cd. im still able to read cd when i bought it maybe year ago but now it cant. any ways to fix it aside from buying a new one?
hacking the Net using typewriter :D
Sounds like the laser may be bad. 4X burners are old. period. You can pick up a new 20X for under $40 shipped.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
DVD drives use separate lasers for CD reading/burning. Usually the DVD laser dies first, but it sounds like your CD laser is gone instead. Usually cleaning doesn't help, as they share the same lens as the DVD laser and that apparently works. But you could give it a try.
Does it just not recognize that a CD is inserted or it sees it but can't read it? But most times it's just easier to replace the unit. -
make that $24 with free shipping.....
no one would even attempt to open and repair one for that little.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005&bop=And&Order=PRICE--
aedipuss - You The Man LOL
If someone can't find a decent burner for less than $40 - they've found themselves shopping the "burner aisle" at a major retailer. Some "evil" online places still try to rob the poor. I knew newegg could come thru.
The last guy that I saw peddling drive repair services wanted $50 to align the laser - on ebay.;/ l ,[____], Its a Jeep thing,
So what's a basic Tivo (read: DVD recorder with built-in Hard Drive) cost?
By snafubaby in forum DVD & Blu-ray RecordersReplies: 14Last Post: 18th Dec 2011, 13:53 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
DVD recorder that will read movie files from ex hard drive?
By siratfus in forum DVD & Blu-ray RecordersReplies: 9Last Post: 3rd Oct 2008, 15:26 -
DVDRW drive cant read DVD Movies - Is it Region Locking or ... ?!?
By quantass in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Apr 2008, 23:45 -
DVD drive won't read DV burned to DVD-R.
By kunfuzed in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 07:49
