Hi all,
I'm putting together a segment using Sony Vegas 6.0. A lot of the footage I'm using is from DVDs; I'm using TMPEGEnc to rip the mpeg stream directly from the discs. Large file sizes, sure, but it allows me to work quickly.
The problem is, some (not all!) of the clips I'm getting play back just fine in MPC, but when I import them into Vegas and preview them on the timeline, they jitter like crazy and drift out of synch almost immediately.
Like I said, I'm having a hard time figuring out what the issue is because it affects some of the discs I'm using, but not all of them. Anyone got any thoughts? I searched the forum but could not find any answers, or even a vague description similar to the problem I'm having.
Thanks in advance!
They could be different framerates - some NTSC will be 23.976 fps with pulldown, some will be 29.970 fps native. G-spot can confirm his for you.
DVD is not a great format to edit without specialty tools, and Vegas 6 is probably not the best version for mpeg work either. All versions of Vegas expand mpeg to the timeline, rather than work with it as native mpeg. You could try converting the footage to either a losslessly compressed format such as lagarith or huffyuv, or a minimally lossy format such as DV. Vegas 6 will work with either of these more easily than mpeg.
One question : are these issues only present in the preview, or do you see them when you render as well ?Read my blog here.
The issues are present in both the preview and the final render. Actually, the 'jitter' disappears in the final render, but the audio still slides out of synch quickly. I think your 23.976 frames theory might be correct.
What would be the best way to convert the MPEG (or DVD ISOs, as I rip all the discs I'm using to ISO before editing) files to huffyuv or DV? -
Virtualdub-mpeg2 and the cenocida or panasonic DV codecs, or Lagarith or Huffyuv codecs. Lagarith output is a little smaller than huffyuv, but both are visually lossless.
Read my blog here.
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 15:06 -
Sony Vegas 10 problems. Cannot render video (no dvd) and cannot youtube
By KariKnutzen in forum EditingReplies: 6Last Post: 10th Jun 2011, 18:25 -
VirtualDub to sony vegas problems HELP
By iTzRingoBrown in forum Capturing and VCRReplies: 3Last Post: 2nd Jul 2010, 12:08 -
Problems using Sony Vegas
By prl in forum EditingReplies: 5Last Post: 24th Jul 2008, 21:49 -
sony vegas 6.0 + Dvd problems
By mp4guy in forum EditingReplies: 8Last Post: 16th May 2007, 23:49
