How good are MP4 camcorders?
I'm not sure if that's the correct name!
I'm referring to the very smal lightweight ones... that store the video on an SD card for example.
What I want to do is records video for the web.
The video quality does need to be good - I don't want anything grainy or not as good as if I recorded from a conventional camcorder.
The biggest display would be 320 x 240 - but also possibly bigger.
Just looking for some feedback before I buy and try!
Thanks.
OM
I have three different Aiptek models and have had decent results with them. My most recent one is a model IS-DV2 (as shown on the packaging). The model shown on the camera itself is DZO-V5T. Features: video (640x480 @ 30FPS max, 4x digital zoom), stills (3mp resolution, 6mp interpolated), digital voice recorder, mp3 player, webcam, and USB drive/SD/MMC reader.
The packaging cites "S-VHS Quality in the Palm of Your Hand," which seems about right. The video wouldn't be confused with the output of my 30gb Panasonic camcorder, but for internet use, it would probably be good enough.
Aiptek has some higher-resolution models, reviewable at www.aiptek.com.
As always, "quality" is in the eye of the beholder. -
The last MP4 video camcorder that I had my hands on was an Aiptek (15fps, 620X480 at best, jerky in all situations), not close to the Panasonic AV devices at 15 fps; nowhere near my current JVC MC200 (DVD quality), or DVD (or HDD) camcorders. Felt cheap, fragile; and I did have time to play with those side-by-side before committing to sell the Aiptek.
The newer offerings (30fps @ 640X480) look much better. I recently saw a Samsung that warranted a look.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Need a *good* software for converting MP4 to AVI ..
By ahmadka in forum Video ConversionReplies: 6Last Post: 24th Nov 2010, 16:44 -
Let's talk about good SD Camcorders...
By hotmetaldobermans in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 16th Jun 2010, 19:00 -
Any good utility to join m2ts (or MTS) from AVCHD camcorders?
By sebaz in forum EditingReplies: 4Last Post: 17th Jan 2010, 12:10 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
What is Nero's MP4 Good for !
By INFRATOM in forum DVD RippingReplies: 31Last Post: 2nd Mar 2008, 19:49
