I am trying to transfer photos from my flash drive to my SD card (for a digital photo frame). The laptop is a Compaq with Windows XP - never had any problems dragging, dropping, burning to CDs etc... Put a brand new 2gb SD card into the laptop's slot and it said "card is not formatted - do you want to format now?", I clicked OK and formatted the card. Tried to drag and drop photo(s) and got error message that card was corrupted. Exchanged card for a new one - thought it was card problem. Put card back into slot, got same formatting message, ignored it (based on what happened the last time) and still will not let me put anything onto this card. Took card and flashdrive to local computer store and they were able to drag and drop - did not get error or formatting message (they are using Vista). So, how do I drag and drop to this SD card? They were able to, so I'm sure there is some way I can as well. Any help you can give is appreciated. Thanks.
Results 1 to 1 of 1
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 7th Oct 2011, 23:01 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51
