In trying to open .txt subs in Subtitle Creator I get an error:
"Error reading subtitle #1 - Input string not in correct format"
These were subs that were done in Subtitle Workshop. Is it because I saved them in "Adobe" format through it?
I have tried to convert the file from UTF8 to ANSI but I still get the error.
The original subs are in "SSA" format. And I saved them as SRT in Subtitle Workshop
Ok, I got Subtitle Creator to take the subs if I convert them to "MicroDVD" format in Subtitle Workshop.
But now I have a new problem. The reason I need to open them in Subtitle Creator is because I need to replace the subtitles I have in an already created DVD, so I am using the method in the sticky guide.
The problem is that I need to replace all of my ":" in the timecodes with ";" the only way to do this is with a program like Ultra Edit or even Notepad (Sub Workshop does not let you replace items in the timecode). But when I then go to input the sub into Sub Workshop it does not recognize it (even though it did prior to the : to ; change) I have saved as ANSI, UTF, and Unicode and it will not take them now. -
Why are you changing the colon to a semicolon?Originally Posted by kpic
Of course Subtitle Workshop cannot use the file after you have messed up the time code by doing that.
Paste a few lines from your subtitle file so we can see what you have. -
Ok, that would explain why SW will not take the file.
I need it in semicolons because that is what Adobe Encore needs for NTSC video (the colons would lose sync after a while) something about non drop frame and drop frame is what they explained? I have already authored some DVDs though and I wanted to easily? replace the subtitle stream in the DVD without re-authoring using METHOD 2 in this guide here: https://forum.videohelp.com/topic338721.html
So here is what my .txt file looks like now
00;04;30;29 00;04;34;15 I feel like he was born
only yesterday!
00;04;35;07 00;04;36;28 The older, the faster.
00;04;37;10 00;04;40;27 Hey, who's an old man?
I guess all I need really is to convert that file into a .SUP file. The guide says use Subtitle Creator to do that. -
If you really need to do this, you can convert a standard format subtitle file to a custom format, in Subtitle Workshop.
See the online help, sec "1.7 Custom formats". -
1- Get Subtitle Creator (google for it, it's free)
2- Open SRT file in Subtitle Creator, if you get a "Input string was not in a correct format" error, go to Formatting - Select character encoding as 1258 - Vietnamese. Your subtitle should be loaded properly. If you get other error messages like "index out of bound", your SRT file may have invalid characters or spaces or whatever, you have to fix it first. Try something like VobSub - Sub Resync to fix subtitle timelines....
3- Once your SRT file is loaded in SC, open File - Save VOBSUB. That will convert your SRT text subtitle file to image subtitle file
(idx & sub). Drop these files into the same folder with your movies and rename to same movies file name and enjoy !!! -
After you load the google translate SRT with -> instead of --> and then save the SRT it will be fixed after saving
problem with Subtitle Creator
By heof in forum SubtitleReplies: 12Last Post: 17th Jul 2010, 02:14 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 23:47 -
Subtitle colours in subtitle creator
By Belfour in forum SubtitleReplies: 3Last Post: 22nd Oct 2009, 03:00 -
Subtitle Creator filter???
By aslan in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 10:38 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59
