To guarantee removal - if you don't need menus: Movie-Only mode.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
This will be used for playback on the SA a majority of the time, but for those other times, is an autorun file required to be able to play on my computer (will I get an error or other problem if there is none)?
I've attached an image showing the main contents of the directory. I'd like to be completely sure before I use a DL disc. The following marked files will be removed prior to burning using ImgBurn.
Removing audio files from BD backup
By dvbuljan in forum Blu-ray RippingReplies: 8Last Post: 18th Nov 2010, 17:43 -
Removing audio tracks from DVD
By txl in forum Authoring (DVD)Replies: 2Last Post: 26th Nov 2009, 12:06 -
Removing Dvd Pin?
By Paulus29 in forum DVD RippingReplies: 3Last Post: 30th Sep 2008, 11:15 -
Bourne Supremacy; Interactual Player software included and unable to backup
By videobruce in forum DVD RippingReplies: 9Last Post: 28th Dec 2007, 11:39 -
Removing menu's music from DVD
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 23:22
