I'm trying to do a text overlay, per this guide:
https://forum.videohelp.com/topic344845.html
It's for my boss at work, who is using a Logitech Webcam. However, no program I use will recognize the video. When I open up his logitech software, it says it is being saved as a .avi file, but when I used "alltoavi" software, it reads as WMV2. A properties lookup reveals the same. I then went and got virtualdub13c and another Virtualdub, but they both say asf/wmv not supported, even the virtualdub I downloaded specifically for wmv/asf.
Is there anything I can do to convert this file to a normally recognized video format?
I'd check logitechs website for more information. It's probable they have a proprietary conversion software for their own file format. If not they should at least offer recommendations for conversions.
Also load the file into GSPOT and you will find the true codec that was used. That should help a little.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks Krispy, I'm checking that out right now.
One final question. Lets say I can't get this to work, or it's just too much of a hassle. What simple free program would you all use for webcam capture? The logitech one is so simple, click one button and start recording, but it's a PITA afterwards! -
I've never used one myself. But you may want to dig through the Logitech software and see if it allows capture to a different format.
Google is your Friend
Logitech Z5500 > Logitech Z906?
By Stealth3si in forum ComputerReplies: 2Last Post: 9th Nov 2011, 21:10 -
Logitech C615 Webcam HD Question
By The Monkees in forum MacReplies: 0Last Post: 24th Oct 2011, 00:42 -
What's the best way to capture someone speaking from their webcam?
By chrisj in forum Newbie / General discussionsReplies: 25Last Post: 7th Jun 2011, 11:44 -
Taking pictures from Logitech Webcam in 1600*1200 resolution using C#
By rostamiani in forum ProgrammingReplies: 0Last Post: 28th Jan 2010, 04:08 -
Software to Convert Webcam Videos for Emailing
By JimBarbasol in forum Video ConversionReplies: 2Last Post: 7th Jun 2009, 11:32
