hi all
I've taken a VOB file, demuxed it into its component M2V and AC3 files. Then I converted the AC3 to a PCM WAV file and did some work on it to replace some parts of it and increase the volume...
I'm now attempting to remux the M2V and WAV files back together using Muxman and I'm getting this error:
Video decoder buffer underflowed 8 times.
Check c:\muxman.log for details.
Resulting DVD will probably not play smoothly.
I've been advised that the bit rate of the WAV may be too high but I don't understand why. Can someone explain what the problem could be and how I can get it to work?
cheers
daz
Closed Thread
Convert it back to ac3 with aftengui. And one post is enough, continue in https://forum.videohelp.com/topic346369.html .
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
