I've always stored DVDs carefully in jewel cases. But I'm getting so many, I'm tempted to just take one of the 50 dvd spindles and store them that way (at least the ones I rarely need to get to).
However, I'm worried that is a BAD THING.
Any thoughts on DVDR storage and what works well, but doesn't take up space? I'm also thinking of using the white paper sleeves, or those dvd cases with plastic sleeves.
				Results 1 to 26 of 26
	Spindles are actually a very good way to store DVDs. Consider they use that method for shipping.  DVDs are slightly thicker at the center hub. That keeps the surfaces from touching and causing scratches. I would prefer that over paper sleeves. But I use both methods. If you keep them in sleeves and leave a bit of spacing when you store them vertically in a box, no real problems. The spindle method has the drawback of having to sort through the spindle for the DVD you want. DVDs are slightly thicker at the center hub. That keeps the surfaces from touching and causing scratches. I would prefer that over paper sleeves. But I use both methods. If you keep them in sleeves and leave a bit of spacing when you store them vertically in a box, no real problems. The spindle method has the drawback of having to sort through the spindle for the DVD you want.
 A lot depends on how many times you need to access the discs. The more you handle them, the more risk of damage. And the environment matters. If you have a lot of dust in the air, you need to be more careful. If you need more space with jewel boxes, look into the slim jewel boxes. About one half the space of the regular boxes.
 But there are many opinions on all this.....
 And welcome to our forums.
	Lately I've been using "CD wallets" to store my DVD discs. I like this because I can actually SEE the disc and just "page though" until I find what I'm looking for etc.
 The spindle method is a pain in the ass because you can never find anything easily.
	For those of us with ridiculous numbers of burned discs, say several hundred and up, the original spindles they came on remains the safest, most space-efficient and cost-effective method of storage. After a certain point, boxes, sleeves and pages in binders lose their allure: they just take up too damn much space. And when we're truly honest with ourselves and admit we are NEVER going to watch 85% of this stuff more than once a decade, the minor inconvenience of searching thru a spindle stack is no big deal. You just keep an overall list on your computer of whats in each spindle, that narrows down the search time considerably. I mean let's get real- you other videoholics out there like me know what I'm getting at.
 If you don't make many recordings and you top out at maybe 50 burned discs a year, then plastic pages in binder or album storage becomes a more feasible option. They are much easier to thumb thru to find something and they look nice on a shelf. However, not all are made equally well: you need to check and make sure the plastic pages don't leach the ink from the disc surfaces (assuming you title your discs with a Sharpie like most of us). I have had this happen several times and it totally turned me off to page storage: the discs end up looking like crap, the pages are ruined, and who knows what chemical reaction might be happening to the discs themselves. I suppose there are expensive archival pages available, but that runs into major money if you have hundreds if not thousands of discs.
 Alternatively, if you have enough space in your house and the patience to manage a ton of individual discs, you could follow the method used by a few of my crazed friends for all their underground audio CDs: they put each one in a paper sleeve, label the sleeve using some sort of organizing scheme that makes sense to them, and then store them in lateral file cabinets similar to what you see in business offices. Each drawer holds hundreds of discs, and they are easily flipped thru as if they were index cards. I'm impressed as hell whenever I visit these characters but know I would never have the patience myself.
 Add me to the "recycle the cakebox spindles" group.
	Thanks for the welcome - I was going to say "I've been here since 2004, but I haven't LOGGED in since Feb 19, 2005 (I thought the same date 3 years later was interesting.)
 And yes - the spindle would be for things like old backups that I want to keep, but don't need to get to often.
	As for the worst way to store discs, there is a type of DVD case that has slide-in holders that holds the discs on the edge, not by the center hole. This type case can cause a slight warping of the disc over a period of time and make them unplayable.
	Wallets are known to warp discs, as well as cheap jewel/DVD cases.
 Spindles are the safest -- BUT -- only in a dark place (inside a file cabinet, for example). Light harms discs. Leaving them in an open room on a shelf will kill the outer edges of the disc.
 Poor storage accounts for a large majority of BS "my disc died" complaints.Want my help? Ask here! (not via PM!)
	In conjunction with Lord Smurf's response, If you do use the spindle cases you can always make a paper covering for them (or better yet, fit a black garbage bag over the spindle cover). If I go with the spindle method (might be in my very foreseeable future), I would do what I just described. This way it keeps the light out if you do not have a darker place to store them
	I do blue paper (because it's Smurfy!) with the spindle number written in black on the side. Want my help? Ask here! (not via PM!)
	I currently use vinyl sleeves (with the soft padding, clear) similar (or identical) to the ones you find in the Meritline Storage Cases - stored in bins, alphabetized. I estimate the size of the collection be be approaching 1,000. ;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
	I use spindles for storage and keep an empty 100 spindle close by the stored spindles with a few foam washers on the bottom of the shaft and a few more lying on the bottom of the cake box. That way I can move a stack off the spindle with the disc I want to the empty 100 spindle and put a washer on top of them and then grab another stack and repeat until I get to the disc I want. The washers in between stacks and the few washers on the bottom of the shaft make the stacks easy to grab when it comes time to move them back to the original spindle.
	Possibly some of the worst places to store discs would be in areas where extreme temperatures, sunlight, humidity and / or dampness occur such as attics, cars and basements.
 Also, avoid using adhesive labels.
	I like those multi dvd cases, 4dvd's, 6 dvd's, 8 dvd's. At least you put a small number of similar content dvd's and get to them reasonably quick, and make some sort of cover on the outside.
	I use slim jewel cases, stored in a CD cabinet which is stored in a closet. Minimum light. I'm just over 500 discs now, and the cabinet will hold over 1100. Really doesn't take up much space at all. By far, it's been the best for maintaining the condition of the discs, and ease of access. I have them numbered, and have them listed on a sheet by name and number.
 I don't do sleeves or anything else that allows direct physical contact with the burned surface - eventually it will scuff or scratch.
	After reading these suggestions, I have decided to store some of my DVDs in the empty spindles I have. I just have one concern: I have labelled all the discs with a sharpie marker, can the ink from the marker damage the disc stacked on top with time?
	I use wallets and am converting over for the newer stuff to plastic sleeves.
 Do not use vinyl sleeves. Those are dangerous. Real vinyl is not just polymerized vinyl chloride, it has softeners. This stuff is known to damage color negatives and prints. Also it sticks to many plastics making it hard to get a disc out of the envelope if its been in long.
 I am using some teknmotion stuff I bought at work. It doesn't say what type of plastic but it doesn't smell like vinyl. Its not perfectly clear so it may be polyethylene. Mylar and other polyesters should work quite well. They are usually quite clear.
 I don't trust most paper. It scratches the lenses of my "glasses".
 I do like the idea of using the spindles. They stack and it will keep them out of the landfills.
 Anyone got a favorite cataloging system. Preferably free. The thought of typing in all the DVD's I have is daunting. I know some people buy bar code scanners for this but I can't justify the expense and besides all but newest cases are in storage.
	No, not at all. Sharpie-brand markers do NOT have any acidic/toxic chemicals that would "eat" through a disc. That is a really bad myth. The worst thing that can happen is you stack recently-labeled discs, where the ink was not fully dry, and it smudges the above disc.Originally Posted by blues1999
 Search the forum, off-topic I think. Several have been discussed before, sometime in 2006-2007 I believe. I downloaded a few of them. Several free ones, also some mega-cheap ones.Anyone got a favorite cataloging system. Preferably free. The thought of typing in all the DVD's I have is daunting. I know some people buy bar code scanners for this but I can't justify the expense and besides all but newest cases are in storage.Want my help? Ask here! (not via PM!)
	I am using Paper Sleeves for CD-ROM without window. With the flap. You can print some info and even artwork for easy recognition. All of my DVDs and software CDs go there.
 http://dsgi.com/cgi-local/SoftCart.exe/cgi-local/pagegen_cdr.pl?U+scstore+fdbx2100ff68...ng_sleeve.html
 taboo
 PS. Today in the morning I throw in the garbage around 700 slightly used CD Jewel Cases
	I sold my last 500 jewel cases on eBay for $20 plus shipping.  Want my help? Ask here! (not via PM!) Want my help? Ask here! (not via PM!)
	I estimate that I am around 1000-1100 discs in total. I have purchased six large capacity wallets. They have a padded soft cover, zip up to keep light off the discs, and store 256 discs each (still in the process of filling them). They are really convenient - I can flip through them easily to find a disc, and they occupy a shelf in a dry cool cupboard under the stairs. I know from the colour of the folder roughly what is in them - docos, films, misic vids, mini-series etc and finding stuff in each folder is really easy from there. I have smaller 20 and 80 disc wallets that I can use to take discs I want with me when I travel (usually unwatched TV shows that I can watch on the Laptop on work trips) - usually I duplicate the one I want onto a cheapo RW as I don't want the main copy damaged.
	I also follow the color coded DVD Wallets, where I used to use
 DVD Slim ( 7mm) cases from Sam's Club. After my inkjet printer died,
 I decided against the whole "make a pretty case, put the disc on the shelf"
 tact, and just went with color coded wallets.
 I buy my wallets from Supermediastore.com. I buy the Red, Blue, Black
 ( and sometimes Green when their available) 420 disc wallets.
 So far I am up to 14 wallets. ;-P.
 Grouped as follows:
 Red=Horror/Sci-Fi ( both domestic and international)
 Blue= Action
 Green= Drama / Comedy
 Black= HK / Anime / TV Shows
 I also have a few ( 20 or so) 128 disc wallets I bought at WalMart
 on clearance for $3 each ( they look like athletic jerseys on the front)
 that hold all my pron. ;-p
 All stored in upright, zipped closed On bookshelves in the den.
 Eventually, I plan on moving away from discs, and going strictly
 to HDs, as HDS are becoming cheaper and cheaper...."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	I use jewel cases just dont double stack and take care of the case
	Vinyl sleeves are BAD?
 I've been buying these from Shop4Tech for my "replaceable and nonessential" discs for about a year now to save space and money
 http://www.shop4tech.com/item6052.html
 I thought I had done enough research last year and established that those, unlike paper sleeves, were OK. But they're not?
 How about Polypropylene sleeves like these from Uline?
 http://www.uline.com/Browse_Listing_5167.asp?desc=Polypropylene+CD%2FDVD+Envelope
 And while, I'm at it, how good are those black slimline dvd cases? I put my "nonreplaceable and very essential" discs in those.
 http://www.supermediastore.com/black-single-slim-dvd-case.html
 What is the official word on best protection for dvds you plan on keeping until you go to your grave?
 Is it spindles ONLY? Lordsmurf and all experts, Help!
	Vinyl sleeves are not good for long term storage. They slowly react with polycarbonate discs and can cause the surface of the disc to cloud.Originally Posted by justmehere17
	I use double sided sleeves for archive from CaseLogic; http://www.caselogic.com/100_disc_capacity_double_sided_prosleeveii_reg/product_detail...?modelid=56554 They have a Tyvek paper on the data side. Probably not the best compared to cakeboxes or a decent jewel case, but they work for me. And they are very compact for storage. If you have to access/remove your discs often, then jewel cases may be a better option.
  Best and worst DVD+R DL mediaBy Persistence in forum MediaReplies: 22Last Post: 25th Sep 2011, 19:16
  Even at our worst, this forum is still friendlyBy lordsmurf in forum FeedbackReplies: 12Last Post: 16th Feb 2009, 18:58
  Please rank my VCRs from best to worst.By theaveng in forum Capturing and VCRReplies: 22Last Post: 15th Dec 2008, 14:41
  Worst DVD EverBy videobread in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 23:28
  The Worst Technology LawsBy rkr1958 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2007, 19:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
