Currently backing up my DVDs. Want to save space on the DVDR by stripping out extras while retaining the DVD menu..
Is there a good tool for this?? I've been Googling and cannot find anything that does just this.
Using WinXp.
Thanks.
And here's the guide:
http://download.videohelp.com/jsoto/guides/VobBlanker/blanking/index.php -
Depends on whether you want temporary or permanent freeware or are willing to pay for convenience. A good compromise might be to download the 30-day free trial version of CloneDVD with AnyDVD. This is what I eventually purchased, it is software optimized to do exactly what you're asking. You can delete anything you don't want and the backup will still include the original DVD menu tree. It will be fully functional to select scenes, etc. If you select a menu option on the backup that you had deleted, your screen will just blank for a second and then return to the menu to let you know the item is gone.
For speed, ease of use and reliability in deleting items CloneDVD/AnyDVD can't be beat, especially if you have a reasonable number of DVDs to back up and can manage to do your entire collection within the 30 day free trial period. If it expires before you finish, you can either buy the activation key if you feel its worth it (I did) or move on to some of the freeware programs discussed in the forums.
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 09:36 -
How?: HD mpg .ts to DVD, retaining 5.1
By TheMgnt in forum Video ConversionReplies: 22Last Post: 19th Nov 2010, 16:44 -
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 13:05 -
Mts to DVD/MPEG2 retaining 5.1 Audio
By mukeshs in forum Video ConversionReplies: 0Last Post: 18th Feb 2010, 14:46 -
Add subtitle, keep menu/extras
By canaQ in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 06:36
