hi all,
new to the forum, its a great source of info.
i'm looking to buy a blu ray player, but i want to buy a player that can be hacked to play all region standard dvd's.
i have a lot of region 1 and 2 disks and all my standard players at home are multi region.
are there any blu ray players out at the moment that can be hacked to play all region 1-6 disks?
thanks for the help
None of the current HD players (HD-DVD or Blu-Ray) can be hacked to region free for SD DVD's.
So you are stuck needing to use two players. Just ensure your SD region free player is also a quality Divx player, and you have all the bases covered.Google is your Friend -
I am wondering whether PS3 also the same (no SD DVD multi region?)
I't may be worth trying to contact this company as you are in Ireland,they seem to have cracked the bluray region coding,it might apply to the dvd region as well
http://www.stegen.com/index.php -
The only HD player to be hacked was the Toshiba HD-XA2,unfortunately it won't be made anymore:
http://www.avsforum.com/avs-vb/showthread.php?t=988167 -
Well the only reason I wait for my PS3 purchase is this. I live in region 3 but almost all my disc is NTSC disc that vary from region 1 to all region. I have only few PAL DVD and that also region 2 DVD.
In fact, I don't have region 3 DVD at all :P
Recommendation for Blu-Ray player that can have region free DVD
By noob1391 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Oct 2012, 06:17 -
Blu-Ray Player That can be Made Multi-Region, and Plays Divx USB?
By rdinsf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2012, 07:19 -
are there any blu-ray players that can be made region free for dvd's?
By CODEWERKX in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2009, 13:26 -
Multi-Region Hacks for SD DVD Playback Using Blu-ray Players
By Big C in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Jul 2008, 18:27 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
