when i run Sherlock i get this:
when th codecs list is up, ther's 2 lines in red...:
CoreAVC Video Decoder
FLV Video Decoder
when i'm clickin on one of them i get this:
what is it all about?
how can i re-install/un-install?
do i even need those?
thanks in advanced!
Results 1 to 24 of 24
Codec Sniper is one removal tool. CoreAVC is probably for H.264 video. Looks like you still have a CyberLink codec that will still work. FLV is probably for flash videos. Probably used for browser playback of online files. Easy enough to reinstall if needed.
Thanks for the help man.
the warning at the bottom of this tool freaked me out a lil bit...
"BE CAREFUL!!! This little tool can turn your video machine into an unusable state"
usually i dont let phrases as this one to intimidate me... :P
but this list is to much for me.
first - it shows that all codecs' status is "o.k."...
second - i cant recognize the FLV codec and PowerDVD got so many codecs on my PC!!! (maybe too much...)
here's Codec Snipers diagnosis:
Thanks again!!!Code:0#Direct Show#WMT MuxDeMux Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 1#Direct Show#PDR MPEG-1 Splitter#C:\Program Files\CyberLink\PowerDirector\PDM1Splter.ax#-#2.3.1118 #ok 2#Direct Show#Dirac Source#C:\WINDOWS\system32\DiracSplitter.ax#-#1, 0, 0, 0#ok 3#Direct Show#Matroska Source#C:\WINDOWS\system32\DiracSplitter.ax#-#1, 0, 0, 0#ok 4#Direct Show#PDR TS Information#C:\Program Files\CyberLink\PowerDirector\pdtsinfo.ax#-#1.0.1926 #ok 5#Direct Show#Nero Scene Detector 2#C:\Program Files\Common Files\Ahead\DSFilter\NeSceneDetector.ax#-#4, 2, 0, 27e#ok 6#Direct Show#Nero Digital Audio Decoder#C:\Program Files\Common Files\Ahead\DSFilter\NeAudio.ax#-#4, 2, 0, 27e#ok 7#Direct Show#CyberLink DDR#C:\Program Files\CyberLink\PowerDirector\PDRender.ax#-#2, 0, 2, 26#ok 8#Direct Show#Matroska Splitter#C:\Program Files\CyberLink\PowerDirector\PDRender.ax#-#2, 0, 2, 26#ok 9#Direct Show#PDR Video Stabilizer#C:\Program Files\CyberLink\PowerDirector\CLVideoStabilizer.ax#-#2.0.1501 #ok 10#Direct Show#CyberLink YUY2 Sub-Sampling#C:\Program Files\CyberLink\PowerDirector\PDSubYUY2.ax#-#2.5.0523 #ok 11#Direct Show#WMT AudioAnalyzer#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 12#Direct Show#CyberLink DV Buffer#C:\Program Files\CyberLink\PowerDirector\PDDVBuffer.ax#-#2.00.2607#ok 13#Direct Show#RadLight Ogg Splitter#C:\WINDOWS\system32\RLOgg.ax#-#1.0.0.2#ok 14#Direct Show#Indeo® video 5.10 Compression Filter#C:\WINDOWS\system32\ir50_32.dll#-#R.5.10.15.2.55#ok 15#Direct Show#Cyberlink Scene Detect Filter#C:\Program Files\CyberLink\PowerDirector\PDScnDt.ax#-#1.00.0813#ok 16#Direct Show#CyberLink AudioCD Filter (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\CLAudioCD.ax#-#5.00.4417 #ok 17#Direct Show#CyberLink AVI Audio Time Regulator#C:\Program Files\CyberLink\PowerDirector\PDAVI_AudTR.ax#-#1.00.0724#ok 18#Direct Show#RadLight Vorbis Decoder#C:\WINDOWS\system32\RLVorbisDec.ax#-#1, 0, 1, 1#ok 19#Direct Show#Windows Media Audio Decoder#C:\WINDOWS\system32\msadds32.ax#-#8.00.00.4487#ok 20#Direct Show#RealVideo Decoder#C:\WINDOWS\system32\msadds32.ax#-#8.00.00.4487#ok 21#Direct Show#PDR Video Regulator#C:\Program Files\CyberLink\PowerDirector\CLRGL.ax#-#2.00.5002 #ok 22#Direct Show#CyberLink Audio Decoder (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\CLAud_w.ax#-#6.01.3668#ok 23#Direct Show#WMT Format Conversion#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 24#Direct Show#CyberLink Audio Resampler#C:\Program Files\CyberLink\PowerDirector\PDAuRsmpl.ax#-#2.0.1318 #ok 25#Direct Show#CyberLink DV Reader Filter#C:\Program Files\CyberLink\PowerDirector\PDDVMrd.ax#-#2.01.2211#ok 26#Direct Show#WMT Black Frame Generator#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 27#Direct Show#Nero Resize#C:\Program Files\Common Files\Ahead\DSFilter\NeResize.ax#-#4, 2, 0, 27e#ok 28#Direct Show#CyberLink Audio Effect (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\claudfx.ax#-#6.00.2731#ok 29#Direct Show#Indeo® video 5.10 Decompression Filter#C:\WINDOWS\system32\ir50_32.dll#-#R.5.10.15.2.55#ok 30#Direct Show#WMT Screen Capture filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 31#Direct Show#PDR Audio Effect#C:\Program Files\CyberLink\PowerDirector\PDaudfx.ax#-#6.1.0213 #ok 32#Direct Show#Microsoft Screen Video Decompressor#C:\WINDOWS\system32\msscds32.ax#-#8.00.00.4487#ok 33#Direct Show#PDR SnapShotTIP Filter#C:\Program Files\CyberLink\PowerDirector\PDSShot.ax#-##ok 34#Direct Show#Cyberlink Byte Counter Filter#C:\Program Files\CyberLink\PowerDirector\PDByteCounter.ax#-#1.00.1224 #ok 35#Direct Show#CyberLink Editing Service 4.0 (Source)#C:\Program Files\CyberLink\PowerDirector\cledtkrn.dll#-#4.00.1508#ok 36#Direct Show#PDR MPEG-4 Splitter#C:\Program Files\CyberLink\PowerDirector\PDM4Splt.ax#-#1.0.3229 #ok 37#Direct Show#MPEG Layer-3 Decoder#C:\WINDOWS\system32\l3codecx.ax#-#1, 5, 0, 50#ok 38#Direct Show#CyberLink Audio Digital Transcoder#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\CLADT.ax#-#1.00.0717 #ok 39#Direct Show#Nero Audio Stream Renderer#C:\Program Files\Common Files\Ahead\DSFilter\NeRender.ax#-#4, 2, 0, 27e#ok 40#Direct Show#AAC Parser#C:\WINDOWS\system32\aac_parser.ax#-#1.1#ok 41#Direct Show#PDR TL MPEG Splitter#C:\Program Files\CyberLink\PowerDirector\PDTLMSplter.ax#-#3.2.2219 #ok 42#Direct Show#ACELP.net Sipro Lab Audio Decoder#C:\WINDOWS\system32\acelpdec.ax#-#1.40#ok 43#Direct Show#RadLight APE DirectShow Filter#C:\WINDOWS\system32\acelpdec.ax#-#1.40#ok 44#Direct Show#Nero Digital AVC Audio Encoder#C:\Program Files\Common Files\Ahead\DSFilter\NeNDAud.ax#-#4, 2, 0, 27e#ok 45#Direct Show#Nero Digital AVC File Writer#C:\Program Files\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4, 2, 0, 27e#ok 46#Direct Show#Nero Digital AVC Null Renderer#C:\Program Files\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4, 2, 0, 27e#ok 47#Direct Show#Nero Digital AVC Muxer#C:\Program Files\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4, 2, 0, 27e#ok 48#Direct Show#Nero Digital AVC Video Enc#C:\Program Files\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4, 2, 0, 27e#ok 49#Direct Show#CyberLink SAC Video Decoder(PDVD7 HomeNetwork)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLVSD.ax#-#6.0.2122 #ok 50#Direct Show#CyberLink SnapShot Filter#C:\Program Files\CyberLink\PowerDirector\PDSnapShot.ax#-#1, 0, 3, 26#ok 51#Direct Show#Nero QuickTime(tm) Video Decoder#C:\Program Files\Common Files\Ahead\DSFilter\NeQTDec.ax#-#4, 2, 0, 27e#ok 52#Direct Show#FLV Splitter#C:\Program Files\Common Files\Ahead\DSFilter\NeQTDec.ax#-#4, 2, 0, 27e#ok 53#Direct Show#File Source (Netshow URL)#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 54#Direct Show#Nero Digital AVC Subpicture Enc#C:\Program Files\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4, 2, 0, 27e#ok 55#Direct Show#Nero Format Converter#C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax#-#4, 2, 0, 27e#ok 56#Direct Show#PDR Video Effect#C:\Program Files\CyberLink\PowerDirector\CLVidFx.ax#-#1.0.3905 #ok 57#Direct Show#WMT Import Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 58#Direct Show#Bitmap Generate#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 59#Direct Show#CyberLink YUY2 DeInterlace#C:\Program Files\CyberLink\PowerDirector\PDDitlYUY2.ax#-#2.1.0515 #ok 60#Direct Show#Windows Media Video Decoder#C:\WINDOWS\system32\wmvds32.ax#-#8.00.00.4487#ok 61#Direct Show#Windows Media Video Decoder#C:\WINDOWS\system32\wmv8ds32.ax#-#8.0.0.4000#ok 62#Direct Show#Nero Photo Source#C:\Program Files\Common Files\Ahead\DSFilter\NePhotoSource.ax#-#4, 2, 0, 27e#ok 63#Direct Show#PDR DVSD Modifier#C:\Program Files\CyberLink\PowerDirector\dvsdModifier.ax#-#1.00.0930#ok 64#Direct Show#CyberLink Demux (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\NavFilter\CLDemuxer.ax#-#1.0.4528 #ok 65#Direct Show#PDR MPEG-2 Splitter#C:\Program Files\CyberLink\PowerDirector\PDM2Splter.ax#-#2.3.1118 #ok 66#Direct Show#CyberLink MPEG Splitter(Scramble)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLSplter.ax#-#3.1.1424 #ok 67#Direct Show#WMT VIH2 Fix#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 68#Direct Show#Dirac Splitter#C:\WINDOWS\system32\DiracSplitter.ax#-#1, 0, 0, 0#ok 69#Direct Show#CyberLink AudAna Filter#C:\Program Files\CyberLink\PowerDirector\PDAudAna.dll#-#2.00.1520 #ok 70#Direct Show#CyberLink Scene Detect Filter 2#C:\Program Files\CyberLink\PowerDirector\PDScnDt2.dll#-#1.01.3814#ok 71#Direct Show#Nero Video Analyzer#C:\Program Files\Common Files\Ahead\DSFilter\NeVideoAnalyzer.ax#-#4, 2, 0, 27e#ok 72#Direct Show#CyberLink BDROM Navigator#C:\Program Files\Cyberlink\PowerDVD\NavFilter\CLBDROMNav.ax#-#1.0.0.2602#ok 73#Direct Show#Record Queue#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 74#Direct Show#Nero ES Video Reader#C:\Program Files\Common Files\Ahead\DSFilter\NDParser.ax#-#4, 2, 0, 27e#ok 75#Direct Show#PDR Demultiplexer#C:\Program Files\CyberLink\PowerDirector\PDDemuxer.ax#-#1.0.4930 #ok 76#Direct Show#CyberLink Line21 Decoder (PDVD7.x)#C:\Program Files\Cyberlink\PowerDVD\VideoFilter\CLLine21.ax#-#4.0.7311 #ok 77#Direct Show#Cyberlink Sub-Picture Filter#C:\Program Files\CyberLink\PowerDirector\PDSubPic.ax#-#3.00.0728#ok 78#Direct Show#Nero Audio CD Filter#C:\Program Files\Common Files\Ahead\DSFilter\NeAudCD.ax#-#4, 2, 0, 27e#ok 79#Direct Show#Windows Media Multiplexer#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 80#Direct Show#ASX file Parser#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 81#Direct Show#ASX v.2 file Parser#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 82#Direct Show#NSC file Parser#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 83#Direct Show#Xvid MPEG-4 Video Decoder#C:\WINDOWS\system32\xvid.ax#-##ok 84#Direct Show#CyberLink VAudAna Filter#C:\Program Files\CyberLink\PowerDirector\PDVAudAna.dll#-#1.01.0826#ok 85#Direct Show#PDR MPEG Video Encoder#C:\Program Files\CyberLink\PowerDirector\PDVidEnc.ax#-#6.3.1416 #ok 86#Direct Show#CyberLink DV Filter#C:\Program Files\CyberLink\PowerDirector\PDDVTCR.ax#-#2.01.1524#ok 87#Direct Show#CoreAAC Audio Decoder#C:\WINDOWS\system32\CoreAAC.ax#-#1, 2, 0, 575#ok 88#Direct Show#Windows Media source filter#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 89#Direct Show#Frame Eater#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 90#Direct Show#Nero DVD Navigator#C:\Program Files\Common Files\Ahead\DSFilter\NeDVD.ax#-#4, 2, 0, 27e#ok 91#Direct Show#CyberLink Push-Mode CLStream (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLStream(PushMode).ax#-#1, 0, 0, 1524#ok 92#Direct Show#CyberLink Audio Decoder (PDVD7 UPnP)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLAud.ax#-#6.00.1803#ok 93#Direct Show#WST Decoder#C:\WINDOWS\system32\wstdecod.dll#-#5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 94#Direct Show#PDR H.264/AVC Decoder#C:\Program Files\CyberLink\PowerDirector\pd264dec.ax#-#1.7.2029 #ok 95#Direct Show#RealMedia Source#C:\Program Files\CyberLink\PowerDirector\pd264dec.ax#-#1.7.2029 #ok 96#Direct Show#Nero Audio Sample Renderer#C:\Program Files\Common Files\Ahead\DSFilter\NeRender.ax#-#4, 2, 0, 27e#ok 97#Direct Show#CyberLink Audio Spectrum Analyzer (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\CLAudSpa.ax#-#1.00.0924 #ok 98#Direct Show#Nero Vcd Navigator#C:\Program Files\Common Files\Ahead\DSFilter\NeVCD.ax#-#4, 2, 0, 27e#ok 99#Direct Show#DivX Decoder Filter#C:\Program Files\CyberLink\PowerDVD\VideoFilter\DXdec.ax#-#6.0.0.1571#ok 100#Direct Show#Nero Audio Processor#C:\Program Files\Common Files\Ahead\DSFilter\NeAudioConv.ax#-#4, 2, 0, 27e#ok 101#Direct Show#Frame Drop Filter#C:\Program Files\CyberLink\PowerDirector\PDFrameDrop.ax#-#1.0.0.1#ok 102#Direct Show#PDR Audio Decoder#C:\Program Files\CyberLink\PowerDirector\PDAUD.ax#-#6.01.3417#ok 103#Direct Show#WMT Sample Information Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 104#Direct Show#PDR MPEG Muxer#C:\Program Files\CyberLink\PowerDirector\PDMpgMux.ax#-#5.0.3705 #ok 105#Direct Show#Nero Mpeg2 Encoder#C:\Program Files\Common Files\Ahead\DSFilter\NeVCR.ax#-#4, 2, 0, 27e#ok 106#Direct Show#VBI Surface Allocator#C:\WINDOWS\system32\vbisurf.ax#-#5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 107#Direct Show#Microsoft MPEG-4 Video Decompressor#C:\WINDOWS\system32\mpg4ds32.ax#-#8.00.00.4487#ok 108#Direct Show#PDR M2V Writer#C:\Program Files\CyberLink\PowerDirector\PDM2VWriter.ax#-#1.03.2017#ok 109#Direct Show#Nero Video Stream Renderer#C:\Program Files\Common Files\Ahead\DSFilter\NeRender.ax#-#4, 2, 0, 27e#ok 110#Direct Show#DivX Demux#C:\WINDOWS\system32\DivXMedia.ax#-#0.0.0.028#ok 111#Direct Show#CyberLink Video/SP Decoder (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\VideoFilter\CLVSD.ax#-#6.0.3722 #ok 112#Direct Show#CyberLink BDRE Navigator#C:\Program Files\Cyberlink\PowerDVD\NavFilter\CLBDRENav.ax#-#1.0.0.2602#ok 113#Direct Show#Nero PS Muxer#C:\Program Files\Common Files\Ahead\DSFilter\NePSMuxer.ax#-#4, 2, 0, 27e#ok 114#Direct Show#WMT Log Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 115#Direct Show#WMT Virtual Renderer#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 116#Direct Show#PDR File Reader (Async)#C:\Program Files\CyberLink\PowerDirector\PDReader.ax#-#2.0.0812 #ok 117#Direct Show#CyberLink Transform Tee#C:\Program Files\CyberLink\PowerDirector\PDTee.ax#-#3.0.0730 #ok 118#Direct Show#RealAudio Decoder#C:\Program Files\CyberLink\PowerDirector\PDTee.ax#-#3.0.0730 #ok 119#Direct Show#PDR Dump Filter#C:\Program Files\CyberLink\PowerDirector\PDDump.ax#-#4.0.02.17 #ok 120#Direct Show#CyberLink DV Dump Filter#C:\Program Files\CyberLink\PowerDirector\PDDVDump.ax#-#2, 1, 34, 28#ok 121#Direct Show#PDR TimeStretch Filter(CES)#C:\Program Files\CyberLink\PowerDirector\clauts.ax#-#1.0.4024#ok 122#Direct Show#CyberLink DVD Navigator (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\NavFilter\CLNavX.ax#-#7.00.2523#ok 123#Direct Show#PDR Dump Dispatch Filter#C:\Program Files\CyberLink\PowerDirector\PDDumpDispatch.ax#-#1.2.1.2412#ok 124#Direct Show#CyberLink TimeStretch Filter (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\clauts.ax#-#1.0.4024#ok 125#Direct Show#Cyberlink SubTitle Importor#C:\Program Files\Cyberlink\PowerDVD\VideoFilter\CLSubTitle.ax#-#1, 0, 0, 1604#ok 126#Direct Show#RadLight Speex Decoder#C:\WINDOWS\system32\RLSpeexDec.ax#-#1, 0, 0, 0#ok 127#Direct Show#Nero Splitter#C:\Program Files\Common Files\Ahead\DSFilter\NeSplitter.ax#-#4, 2, 0, 27e#ok 128#Direct Show#AC3Filter#C:\Program Files\AC3Filter\ac3filter.ax#-#1.31b#ok 129#Direct Show#.RAM file Parser#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 130#Direct Show#CyberLink Real File writer#C:\Program Files\CyberLink\PowerDirector\PDRMFileWriter.ax#-#1.00.3307#ok 131#Direct Show#Nero File Source / Splitter#C:\Program Files\Common Files\Ahead\DSFilter\NeFSource.ax#-#4, 2, 0, 27e#ok 132#Direct Show#CyberLink HDDVD Navigator#C:\Program Files\Cyberlink\PowerDVD\NavFilter\HDDVDNav.ax#-#1.00.0203#ok 133#Direct Show#PDR Audio Encoder#C:\Program Files\CyberLink\PowerDirector\PDAudEnc.ax#-#2.1.1413 #ok 134#Direct Show#CyberLink VidAna Filter#C:\Program Files\CyberLink\PowerDirector\PDVidAna.dll#-#1.00.0126#ok 135#Direct Show#WMT DirectX Transform Wrapper#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 136#Direct Show#G.711 Codec#C:\WINDOWS\system32\g711codc.ax#-#5.1.2600.0 (xpclient.010817-1148)#ok 137#Direct Show#Indeo® audio software#C:\WINDOWS\system32\iac25_32.ax#-#2.05.53#ok 138#Direct Show#Cyberlink Gate Filter#C:\Program Files\CyberLink\PowerDirector\PDGate.ax#-#1, 0, 0, 1#ok 139#Direct Show#Windows Media Update Filter#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 140#Direct Show#CyberLink MPEG-4 Splitter (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\NavFilter\clm4splt.ax#-#1.0.3229 #ok 141#Direct Show#CyberLink HD/BD Mixer (PDVD7.x)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\CLHBMixer.ax#-#1.00.1325 #ok 142#Direct Show#Cyberlink DV Scene Detect Filter#C:\Program Files\CyberLink\PowerDirector\PDDVScnDt.ax#-#1.00.0426 #ok 143#Direct Show#ASF DIB Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 144#Direct Show#ASF ACM Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 145#Direct Show#ASF ICM Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 146#Direct Show#ASF URL Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 147#Direct Show#ASF JPEG Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 148#Direct Show#ASF DJPEG Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 149#Direct Show#ASF embedded stuff Handler#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 150#Direct Show#DivX Subtitle Decoder#C:\WINDOWS\system32\DivXMedia.ax#-#0.0.0.028#ok 151#Direct Show#PDR WAV Dest#C:\Program Files\CyberLink\PowerDirector\PDWavDest.ax#-#1.00.6518#ok 152#Direct Show#9x8Resize#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 153#Direct Show#WIA Stream Snapshot Filter#C:\WINDOWS\system32\wiasf.ax#-##ok 154#Direct Show#Nero Video Processor#C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax#-#4, 2, 0, 27e#ok 155#Direct Show#CyberLink AudioCD Filter#C:\Program Files\CyberLink\PowerDirector\PDAudioCD.ax#-#5.00.4417 #ok 156#Direct Show#Nero Video Decoder#C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax#-#4, 2, 0, 27e#ok 157#Direct Show#Allocator Fix#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 158#Direct Show#IDM Filter#C:\Program Files\CyberLink\PowerDirector\PDIDMF.ax#-#1.00.4924 #ok 159#Direct Show#CyberLink VC-1 Decoder (PDVD7.x)#C:\Program Files\Cyberlink\PowerDVD\VideoFilter\CLVC1Dec.ax#-#1.7.7524 #ok 160#Direct Show#WMT Virtual Source#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 161#Direct Show#WMT Interlacer#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 162#Direct Show#Nero Audio CD Navigator#C:\Program Files\Common Files\Ahead\DSFilter\NeAudCD.ax#-#4, 2, 0, 27e#ok 163#Direct Show#FLV Source#C:\Program Files\Common Files\Ahead\DSFilter\NeAudCD.ax#-#4, 2, 0, 27e#ok 164#Direct Show#Nero Scene Detector#C:\Program Files\Common Files\Ahead\DSFilter\NeSceneDetector.ax#-#4, 2, 0, 27e#ok 165#Direct Show#Uncompressed Domain Shot Detection Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 166#Direct Show#XML Playlist#C:\WINDOWS\system32\wmpasf.dll#-#10.00.00.3802#ok 167#Direct Show#CyberLink Audio Decode (PDVD7.x)#C:\Program Files\Cyberlink\PowerDVD\AudioFilter\claud_HBD.ax#-#8.01.7602#ok 168#Direct Show#Nero File Source#C:\Program Files\Common Files\Ahead\DSFilter\NeFileSrc.ax#-#4, 2, 0, 27e#ok 169#Direct Show#Nero QuickTime(tm) Audio Decoder#C:\Program Files\Common Files\Ahead\DSFilter\NeQTDec.ax#-#4, 2, 0, 27e#ok 170#Direct Show#Nero File Source (Async.)#C:\Program Files\Common Files\Ahead\DSFilter\NeFileSourceAsync.ax#-#4, 2, 0, 27e#ok 171#Direct Show#PDR MPEG1/2 Video Decoder#C:\Program Files\CyberLink\PowerDirector\PDVSD.ax#-#6.0.2130 #ok 172#Direct Show#Nero DVD Decoder#C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax#-#4, 2, 0, 27e#ok 173#Direct Show#Nero Digital Parser#C:\Program Files\Common Files\Ahead\DSFilter\NDParser.ax#-#4, 2, 0, 27e#ok 174#Direct Show#RealMedia Splitter#C:\Program Files\Common Files\Ahead\DSFilter\NDParser.ax#-#4, 2, 0, 27e#ok 175#Direct Show#CyberLink Double Pin Tee#C:\Program Files\CyberLink\PowerDirector\PDDoubleTee.ax#-#1.00.1224 #ok 176#Direct Show#WMT DV Extract#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 177#Direct Show#CyberLink Video/SP BD-HD Decoder (PDVD7.x)#C:\Program Files\Cyberlink\PowerDVD\VideoFilter\CLVSD_HBD.ax#-#6.0.8722 #ok 178#Direct Show#RadLight Theora Decoder#C:\WINDOWS\system32\RLTheoraDec.ax#-#1, 0, 0, 3#ok 179#Direct Show#CyberLink Demux (PDVD7 UPnP)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLDemuxer.ax#-#1.0.3421 #ok 180#Direct Show#Nero Frame Capture#C:\Program Files\Common Files\Ahead\DSFilter\NeCapture.ax#-#4, 2, 0, 27e#ok 181#Direct Show#WMT Switch Filter#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 182#Direct Show#WMT Volume#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 183#Direct Show#Nero Video Sample Renderer#C:\Program Files\Common Files\Ahead\DSFilter\NeRender.ax#-#4, 2, 0, 27e#ok 184#Direct Show#CyberLink HDV Source Filter#C:\Program Files\CyberLink\PowerDirector\PDhdvsrc.ax#-#1.0.0116 #ok 185#Direct Show#CyberLink H.264/AVC Decoder (PDVD7.x)#C:\Program Files\CyberLink\PowerDVD\VideoFilter\CL264dec.ax#-#1.99.1405#ok 186#Direct Show#Stretch Video#C:\Program Files\Movie Maker\wmm2filt.dll#-#2, 1, 4026, 0#ok 187#Direct Show#Dirac Video Decoder#C:\WINDOWS\system32\DiracSplitter.ax#-#1, 0, 0, 0#ok 188#Direct Show#Cyberlink Video Regulator#C:\Program Files\CyberLink\PowerDirector\PDResample.ax#-#2.5.0728 #ok 189#Direct Show#Nero DV Splitter#C:\Program Files\Common Files\Ahead\DSFilter\NeDVSplitter.ax#-#4, 2, 0, 27e#ok 190#Direct Show#CyberLink Stamp Effect#C:\Program Files\CyberLink\PowerDirector\PDStampEffect.ax#-#1.00.1312#ok 191#Direct Show#CyberLink QuickTime writer#C:\Program Files\CyberLink\PowerDirector\PDQTFileWriter.ax#-#1.00.3419#ok 192#Direct Show#CyberLink Streamming Filter (PDVD7)#C:\Program Files\Cyberlink\PowerDVD\UPnP\CLStream.ax#-#1, 1, 0, 1524#ok 193#Direct Show#PDR Audio Noise Reduction#C:\Program Files\CyberLink\PowerDirector\CLAuNRWrapper.ax#-#2.00.1805 #ok 194#Direct Show#PDR MPEG-4 Muxer#C:\Program Files\CyberLink\PowerDirector\PDM4Muxer.ax#-#1.0.2626 #ok 195#Audio-Codec#IMA ADPCM CODEC for MSACM#C:\WINDOWS\system32\imaadp32.acm#msacm.imaadpcm#5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 196#Audio-Codec#Microsoft ADPCM CODEC for MSACM#C:\WINDOWS\system32\msadp32.acm#msacm.msadpcm#5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 197#Audio-Codec#Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM#C:\WINDOWS\system32\msg711.acm#msacm.msg711#5.1.2600.0 (xpclient.010817-1148)#ok 198#Audio-Codec#Microsoft GSM 6.10 Audio CODEC for MSACM#C:\WINDOWS\system32\msgsm32.acm#msacm.msgsm610#5.1.2600.0 (xpclient.010817-1148)#ok 199#Audio-Codec#DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50#C:\WINDOWS\system32\tssoft32.acm#msacm.trspch#1.01#ok 200#Video-Codec#Cinepak® Codec#C:\WINDOWS\system32\iccvid.dll#vidc.cvid#1.10.0.11#ok 201#Video-Codec#Helix I420 YUV Codec#C:\WINDOWS\system32\i420vfw.dll#vidc.i420#R1.02#ok 202#Video-Codec##C:\WINDOWS\system32\ir32_32.dll#vidc.iv31##ok 203#Video-Codec##C:\WINDOWS\system32\ir32_32.dll#vidc.iv32##ok 204#Video-Codec#Intel Indeo® Video 4.5#C:\WINDOWS\system32\ir41_32.ax#vidc.iv41#4.51.16.03#ok 205#Video-Codec#Intel Indeo(R) Video YUV Codec#C:\WINDOWS\system32\iyuv_32.dll#vidc.iyuv#5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 206#Video-Codec#Microsoft RLE Compressor#C:\WINDOWS\system32\msrle32.dll#vidc.mrle#5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 207#Video-Codec#Microsoft Video 1 Compressor#C:\WINDOWS\system32\msvidc32.dll#vidc.msvc#5.1.2600.0 (xpclient.010817-1148)#ok 208#Video-Codec#Microsoft UYVY Video Decompressor#C:\WINDOWS\system32\msyuv.dll#vidc.uyvy#5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 209#Video-Codec#Microsoft UYVY Video Decompressor#C:\WINDOWS\system32\msyuv.dll#vidc.yuy2#5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 210#Video-Codec#Toshiba Video Codec#C:\WINDOWS\system32\tsbyuv.dll#vidc.yvu9#5.1.2600.0 (XPClient.010817-1148)#ok 211#Video-Codec#Microsoft UYVY Video Decompressor#C:\WINDOWS\system32\msyuv.dll#vidc.yvyu#5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)#ok 212#Audio-Codec#Microsoft G.723.1 CODEC for MSACM#C:\WINDOWS\system32\msg723.acm#msacm.msg723#4.4.3400#ok 213#Video-Codec#Microsoft H.263 ICM Driver#C:\WINDOWS\system32\msh263.drv#vidc.m263#5.1.2600.2180#ok 214#Video-Codec#Microsoft H.261 ICM Driver#C:\WINDOWS\system32\msh261.drv#vidc.m261#5.1.2600.2180#ok 215#Audio-Codec#Windows Media Audio#C:\WINDOWS\system32\msaud32.acm#msacm.msaudio1#8.00.00.4487#ok 216#Audio-Codec#Audio codec for MS ACM#C:\WINDOWS\system32\sl_anet.acm#msacm.sl_anet#3.02#ok 217#Audio-Codec#Indeo® audio software#C:\WINDOWS\system32\iac25_32.ax#msacm.iac2#2.05.53#ok 218#Video-Codec#Intel Indeo® video 5.10#C:\WINDOWS\system32\ir50_32.dll#vidc.iv50#R.5.10.15.2.55#ok 219#Audio-Codec#MPEG Layer-3 Audio Codec for MSACM#C:\WINDOWS\system32\l3codeca.acm#msacm.l3acm#1, 9, 0, 0305#ok 220#Audio-Codec#Lame MP3 codec engine#C:\WINDOWS\system32\LameACM.acm#msacm.lameacm#0.9.1#ok 221#Video-Codec#DivX#C:\WINDOWS\system32\DivX.dll#vidc.divx#6.8.0.14#ok 222#Video-Codec#Helix YV12 YUV Codec#C:\WINDOWS\system32\yv12vfw.dll#vidc.yv12#R1.02#ok 223#Video-Codec##C:\WINDOWS\system32\xvidvfw.dll#vidc.xvid##ok 224#Audio-Codec##C:\WINDOWS\system32\ac3filter.acm#msacm.ac3filter##ok
You can easily "format" your PC concerning to Codecs, at least with Windows XP, I fixed a lot of PCs this way :Originally Posted by GangstaRap
- removed all, and I mean all from that CodecSniper List
- removed all .AX from System32
re-installing
- Koepi XVid
- AC3 Filter
- CCCP
- fraunhofer mpeg layer-3
reinstall Windows Media Player
reinstall Nero
reinstalling WMP will recover playback of WMV, and other formats
reinstalling NERO will recover playback of DVDs, MPEGs...etc... -
I would probably just leave them as is, unless you are having playback problems with either format. It looks like you may have other codecs that will work in their place and that may be why your first program showed them as broken. Codec sniper seems to say they're OK.
Most of those codecs appear to be from Nero and Cyberlink and if they are 'getting along' with each other without conflicts, you may not really have a problem.
I'm guessing #87 is your AVC codec and #163 is the FLV. Those also appear to be audio decoders, not video. -
actually, i do have problems playing FLV videos.Originally Posted by redwudz
this is why i've opened Sherlock at the first place...
are you sure that none of the codecs in the list are needed for Windows to work properly?Originally Posted by Delta2
cause this is very nice...
i mean - its a great way to clean my machine from all the junk and i might gonna format all the codecs.
Thank you all for the great help! -
I only recommend to do that in Windows XP
And yes, you can remove everything I said, but only if
- you have Windows Media Player to reinstall
- you have Nero to reinstall ( or repair )
The process :
1) start windows in safe mode
2) remove all codec packages in windows control panel
3) remove all the codec from ConecSniper list
4) remove all .AX files in System32
fixing the system
1) install XVid Koepi
2) install Fraunhofer mpeg layer-3 codec
3) install CCCP
4) install AC3 Filter
Reinstall Windows Media Player
Reinstall NERO -
Delta2,
great, i'll give it a try...
BTW, what are those .AX files?
thanks. -
a bunch of filters/codecs in the systemOriginally Posted by GangstaRap
but be a aware about NERO, you should have the version that comes with Nero Showtime, and Windows Media Player to reinstall
Otherwise you will get into trouble
And of course, after cleaning the system, if you need to playback some exotic format such as RMVB or other, you will need to activate A/V decode in CCCP or reinstall RealAlternative -
does Nero Showtime has some necessary codecs in it?
Is a good version, Nero will just reinstall all you need to playback Mpeg, Mpeg2, etc....
If you have Nero Showtime, and Nero Showtime plays that...then you have what I said
i have WMP 10 installer.
good
do it...."format"
only for Windows XP, and not the stupid Vista -
Done that...
Now,
which codecs do i need to install in order to play and/or encode MKV (ISO Mpeg-4) files and DIV3 files?
TIA!
edit...
Plus i'm having some audio problems...
it seems like there's no sound in AVI files with Lame-MP3 Audio though i installed the lame MP3 DirectShow filter... -
Done that...
Now,
CoreAVC or just enable decode in CCCP
Did't said to install that, I said to install Fraunhofer MP3, it was the fraunhofer team who invented MP3...so why not stick with it ? -
DIV3 I use this one
http://www.doom9.org/Soft21/Codecs/divx_311alpha.exe
is enough -
first of all, i wanted to thank you for your great help! appreciate it!
wish i had a way to pay you back somehow...
CoreAVC is payware...Originally Posted by Delta2
so i'll prefer enable it in CCCP, now, is it the right way to enable ISO Mpeg-4?
marked with blue.
you're definitely right, i thought its the same thing, guess not.Originally Posted by Delta2
anyway, is this the one?
when i'm clickin the link it direct me to an "Unauthorized download"...Originally Posted by Delta2
so i tried Free-Codecs.com and the link for Divx 311 alpha directs me automatically to DivX6 download page - i guess because its include in it. -
menu START - Programs - Combined Community Codec Pack
ffdshow video decoder configuration
in the left side - select first option : codecs
enable to libavcodec for Generic MPG4, other MPEG4, H.264 in the list
And, enable FLV1 for playback youtube videos
then, install THIS and RUN because it will register FLVSplitter and MKVSplitter in your system for the above media types
is this the one?
no, is this one :
http://www.free-codecs.com/download/MPEG_Layer_3_Codec.htm
maybe someone in here can give you that -
Take a look in the tools section, look under Codecs and you will find this: https://www.videohelp.com/tools/DivX_3.11 . That should work.Originally Posted by Delta2In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
For someone who needs here is all STEP-BY-STEP tutorial to restore completely a damaged PC with codecs conflits and issues like that
To clean up the system
ONLY, AND ONLY FOR WINDOWS XP
1) start the system in Safe Mode
2) remove all installed codec packs you have, control panel : add/remove programs
3) use o Codec_Sniper, and remove all, and I mean literally everything in the list
https://www.videohelp.com/tools/Codec_Sniper
4) remove all .AX files in Windows/System32
Be aware not to do a fatal mistake, it is your system path...
At this point you have a perfect clean windows, but a USELESS MEDIA MACHINE, nothing works
RESTORING THE SYSTEM
1) Install Koepi XviD
http://www.free-codecs.com/download/Koepi_XviD.htm
2) Install Fraunhofer MPEG Layer-3
3) Install o AC3-Filter
http://www.free-codecs.com/download/AC3_Filter.htm
4) Install o AC3-ACM decompressor
http://www.free-codecs.com/download/AC-3_ACM_Decompressor.htm
Useful for vdub
5) Install DIV-3, Low-motion
http://www.doom9.org/Soft21/Codecs/XviD-1.1.3-28062007.exe
(EDIT)
Thanks to träskmannen for the alternative link
(/EDIT)
At this point you can play AVI files
NOTE: I also recommend CCCP because is useful for playing Youtube Videos and some other exotic formats. Is a light version of FFDSHOW
How to configure CCCP : just DISABLE ALL codecs, and ENABLE 1-by-1 as you need...
FIX for playing DVDs, Mpegs, WMVs e and other formats
1) Make a repair installation of NERO...it will restore all needed codecs to playback VOBs, DVDs..MPEGs...., and much more
I like NERO, and Nero Showtime is my primary player for DVDs...
Be aware of the version of NERO
2) reinstall Windows Media Player
This will restore all the filters to play WMV and other stuff
FIX for Subtitles
Render for subtitles in order to work with all players
1) Direct vobSub
http://www.free-codecs.com/download/DirectVobSub.htm
Some extra info and DEBUGs
1) VSO ConvertXtoDVD doesn't need codecs. It has and uses it's own libraries
Run VSO in a formated machine and it just works
2) I never discharge this tools to check my system codecs
Graph Edit
http://www.digital-digest.com/dvd/downloads/showsoftware_graphedit_141.html
CCCP Insurgent
http://www.cccp-project.net/download.php?type=cccpi
Codec Sniper
I fixed a lot of PC this way
Delta
http://avi2iso.planetaclix.pt/avi2iso.rar
http://fileforum.betanews.com/detail/AVI2ISO/1191447822/1 -
Thanks for that man,Originally Posted by träskmannen
but i think (correct me if i'm wrong) that the new DivX 6.8 allows you to play and decode Div3.
Delta2, Thanks for the great, useful tutorial!
just one more question...
doesn't AC3 Filter also installing the AC3-ACM decompressor?Originally Posted by Delta2 -
like a new one...Originally Posted by Delta2
it doesn't handle DIVX 3 Low Motion very well but it also didn't handle it well before the "codecs format"... -
Good
don't mess up that again
And never, never ... install packs.... and that crazy FFDSHOW that can ruin your system if YOU DON'T KNOW HOW TO USE IT....just use what I said
Every week there is a new version of FFDSHOW...
sorry, maybe day after day ?
Delta
AIO M$ Developer
www.avi2iso.com
CCCP is a codec pack and yet - its a great one...Originally Posted by Delta2
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 17:40 -
Broken Codecs
By jdubbsmoney in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2009, 20:05 -
Programs crash because of broken codecs
By Stiff in forum Software PlayingReplies: 4Last Post: 26th Jan 2009, 15:22 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
How to fix broken IFO?
By Hamilton in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2007, 03:16
