I've tried imgburn and nero. for img burn it will say address out of range or something like that. here is the nero log
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
(Nero Express)
Recorder: <TSSTcorp CDDVDW SH-S203N>Version: SB01 - HA 1 TA 1 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <SONY CDRWDVD CRX310S >Version: VDK2 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
SONY CDRWDVD CRX310S E: CdRom0
TSSTcorp CDDVDW SH-S203N F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2022MB (2071056kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.2.2008
Burn DVD Image
9:13:03 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
9:13:04 PM #2 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using DVD media
9:13:04 PM #3 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2267540 (503:53.65, 4428MB)
9:13:04 PM #4 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
9:13:04 PM #5 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: TSSTcorp CDDVDW SH-S203N, Media type: DVD-R
Disc Manufacturer ID: <CMC MA> <G. AM3>
Disc Application Code: 64, Disc Physical Code: 193
9:13:04 PM #6 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
9:13:04 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2267541 (2267541) = #2267541/503:53.66
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2267541 blocks [F: TSSTcorp CDDVDW SH-S203N]
9:13:04 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [F: TSSTcorp CDDVDW SH-S203N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4643923968, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2267541 | 2267541 | 0x00
2267541 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
9:13:13 PM #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
9:13:13 PM #10 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
9:13:13 PM #11 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
9:13:13 PM #12 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
9:13:13 PM #13 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
9:13:13 PM #14 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 12x (16,620 KB/s)
9:13:14 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
9:13:14 PM #16 Text 0 File DVDR.cpp, Line 3245
Recording mode: Sequential Recording Mode
9:13:14 PM #17 Text 0 File DVDR.cpp, Line 3401
Start write address at LBA 0
DVD high compatibility mode: Yes
9:13:14 PM #18 Text 0 File Cdrdrv.cpp, Line 10026
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 .@....R.........
03 43 4D 43 20 4D 41 00 - 04 47 2E 20 41 4D 33 00 .CMC.MA..G..AM3.
05 88 80 00 00 00 02 00 - 06 09 0D 14 98 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 07 17 0A 0E 09 04 00 ................
09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ...........2..2.
0D 00 00 D0 00 00 00 00 - 0E 09 1F 39 2F 25 1C 00 ...........9/%..
0F 50 19 29 19 89 B5 00 - 10 88 84 00 04 00 04 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2B 37 2D 29 1B 00 ..........+7-)..
13 50 1D 2D 1F A6 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 0B 45 3D 3B 1F 25 00 ..........E=;.%.
17 30 25 31 0D 8A B5 00 - 18 88 80 00 00 00 00 00 .0%1............
19 00 00 00 00 00 00 00 - 1A 0C 51 51 51 45 2D 00 ..........QQQE-.
1B 90 23 2D 19 79 B5 00 - 1C 88 80 00 00 00 00 00 ..#-.y..........
9:13:14 PM #19 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
9:13:26 PM #20 Text 0 File Cdrdrv.cpp, Line 1367
21:13:26.484 - 㩆吠卓捔牯⁰䑃噄坄匠ⵈ㉓㌰N : Queue again later
9:20:37 PM #21 SPTI -1135 File SCSIPassThrough.cpp, Line 181
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 21 C2 40 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0ac21fc0: Len x10000
0x00 00 01 BA 47 9E D7 32 75 D9 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 C8 1A 73 24 43 11 A0 84 1B
0x90 02 3B FF 75 1F D6 2A 75 85 8A 8E C6 69 4F 44
9:20:37 PM #22 CDR -1135 File Writer.cpp, Line 306
Write error
9:20:38 PM #23 Text 0 File DVDR.cpp, Line 3803
EndDAO: Last written address was 2212415 (21C23Fh)
9:20:38 PM #24 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 12x (16,620 KB/s)
9:20:38 PM #25 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
9:20:41 PM #26 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
9:20:41 PM #27 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
im running windows vista and it always seems to fail at 98% also in imgburn it said it couldnt write the sectors or something. I ve tried with 3 different images and none seem to work
Results 1 to 15 of 15
Thanks for the logs. They were helpful. You're not going to like this, but the problem is your media. You are using CMC made DVD-R discs according to the log. These are just awful. One of my friends uses them and they are horrible. They have bad areas all over them. He asks me to make copies for my brother of what he sends me (old TV stuff not on DVD or VHS) and I have a major nightmare every time with these discs. All kinds of read errors and such. Buy better media. Around here we recommend Taiyo Yuden (you'll have to mail order from http://www.rima.com, SuperMediaStore, NewEgg, etc.) or Verbatim. Throw those discs you have in the trash and if you use better media, your burns should magically start working.
You're using crappy dvd media w/media ID> CMC .
Use better dvd media like VERBATIM or TAIYO YUDEN. Make sure you're using a 80 wire ide cable for your SAMSUNG S203N drive. -
i have 100 of these discs and im down to 20 and they always worked b4 i guess they just suck. So you guys are sure its the media cuz this has never happened before. and the 80 wire ide cable? I have a sata dvd burner i think.Originally Posted by budz
edit: are sony dvd-r's any good? -
Only some Sony discs are good. I think I have read a few posts indicating that packages labled "Made In Japan" are actually Taiyo Yuden, and those are fine, but I have never found any.
Verbatim is what I use. If you are in the USA, either Office Max or Best Buy usually have sales on Verbatim media every few weeks. -
Yup, you're SAMSUNG S203N is a SATA dvd burner. You can try changing the sata cable to see if that helps. But the CMC media id discs you're using is crappy. Buy some VERBATIM dvd media and burn it in your drive. If it fails as well then perhaps your drive is dying a slow death. Make sure you're not surfing the internet while burning and turn off other programs running in the background as well.Originally Posted by Variable
You might try to reduce the burn speed. On junk media this sometimes works.
try 8x or 6x.
tony -
CMC arenīt that bad for me. I use them a lot, to back up cheaply PS2 games and Videos. Maybe 1 or 2 coasters out of a 100 pack. Different Brands, mostly Imation. But burning at half speed needed.
Only for Clients we use verbatim.
And as you said, you burned 80 DVDs without a problem: Media isnīt the only problem.
So youīre problem lies here:
"9:20:37 PM #22 CDR -1135 File Writer.cpp, Line 306
Write error
Burn process failed at 12x (16,620 KB/s) "
Try burning at speed 4x, update your firmware.
Also, youīre burning almost 100% of the available DVD space. Very risky.
Maybe Iīm wrong, so others can help you better. -
I wouldnt trust that media and even he has 100 of them, even in the same spindle the MID can be different and the media quality changes also too.Originally Posted by mohnitor
So, try at 8x and then post back. -
Look at your media. Look for flaws at the outer edge. That is where the errors in the log are occuring.
I have found CMC media to differ in quality based on whose brand actually appears on the spindle. House branded CMC media can have runs of defective disks included with visible problems in the coatings. I have seen this with Staples, Dynex and Nexxtech branded media.
If there are visible physical defects burning at a slower speed will not help you.
I have not seen these defects in name brand CMC media like HP, Imation or TDK.
A smaller image might burn just fine on disks with physical problems at the edge. -
Hi,
I have a similar problem in Dell Inspirion 6400. with TSST DVD+-RW
Whenever I burn a DVD it crashes around 1.8GB around 41% of total space.(Always around 1.8GB)
I tried Verbatim and Philips
Updated Firmware
Contact Dell Support, Initially they told it is a hardware fault and need to replace drive, now they say, it is Problem
with Windows, reinstall my windows.
Anyone please help in this. I have attached the Nero log, I tried other softwares also with similar result.
Regards
Shijo Joseph
burnlog.txt -
Disable that:
Then get better media.Multisession : TRUE
Multisession type: : Start multisession -
I tried Disabling multi session, result is same. It crashed again @1.8GB
Which is better media than Verbatim and Philips? -
shikojoseph
It would have been better if you started your own thread.
Your problem is different from the OP. You are taking responses to his problem as responses to yours. He has provided a great deal more info than you have. Start a new thread, fully desecribe your problems including error messages. If you are using nero post the nero log on your failed burns. If you have to burn a new disk to get the log use the Verbatim - then you won;t get a post telling you to use better media. (Well you probably will - from someone who can't read the log). Tell us the speed and configuration of your computer.
I personally think you have a dead drive. But - Dell support must have a reason why they want you to reload Windows. Find out why. -
Is this a 1st time malfunction, or has your burner functioned properly before this?
To summarize:
1) Check your disk before burning. Check to see there is no lint, smudges, imperfections in the dye.
2) Burn at 4x or less (for now)
3) Update to the latest firmware. Sometimes newer disks have compatibility problems with some burners
4) Don't do anything during the burn. Don't surf. Don't play games. Don't run your antivirus scan. Don't use the computer. Period
5) Try a disk image <4300MB. 4.37GB is the usual limit. 4428MB might be over.
To be honest, all I use is crap cheap media in cakeboxes. CMC and Ritek. I have made <1 coaster in >1000 burns (knock on wood) on a variety of profiles - data, DVD, ISO etc. I think the most common mistake is dust/ finger prints/ lint making the laser unable to write.
Windwos 7 fails burning Windows XP doesn't ...
By deepcut in forum Newbie / General discussionsReplies: 10Last Post: 4th Dec 2011, 07:33 -
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 14:57 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
DVR 633 fails to initalize when burning to DVD
By Howardlan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Nov 2007, 18:46 -
Help Burning a disc fails at 1%
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 7th Jun 2007, 18:16
