Read through this thread to see all the connection modes for my laptop (NVidia 6100GO chipset).
https://forum.videohelp.com/topic344750.html
Yours will be different but the setting process will be similar.
Most important: The TV must be connected and on when you reboot the computer. That is the only way to get NVidia to detect the TV and open the TV settings.
If you connect it DVI-HDMI, it will offer HDMI settings
If you connect it VGA, it will offer VGA resolution settings
And don't forget to follow Samsung's detailed instructions to get the TV to display from the correct input.
Results 31 to 36 of 36
http://www.kiva.org/about -
Thanks a lot. I changed the resolution to 1920*1080 and now i have a signal to my HDTV, and I see the photo of my destop but no icons or fuul desktop configuration. I do not know now where to go to change the setting of TV, like cable type, TV color system etc. I know is at Nvidia panel but I am not find exactly where. Pleaese help me. ThankssssOriginally Posted by edDV
jagabo
Thanks very much. Now I have the video from my PC to HDTV, but the audio is missing. So, on my TV there is the pichture but no sound. Any thing wrong? Thanks again -
DVI doesn't carry audio. You have to run audio separately. You'll probably need a cable like this:
http://www.amazon.com/Audio-Y-cable-Black-3-5MM-2-RCAM/dp/B0002J1LES/ -
Ok than ...Originally Posted by jagabo
Thanks very much to YOU and edDv for all explanations!
DVI PC output to HDMI HD TV input?
By eros in forum DVB / IPTVReplies: 1Last Post: 26th Sep 2010, 01:38 -
RF output to DVI/HDMI Input
By torrentkid in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2010, 02:41 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 09:44 -
How to force a certain format to a DVI output?
By erik1958 in forum DVB / IPTVReplies: 2Last Post: 31st Aug 2007, 01:10
