Hi all -
I'm new to the world of binary newsgroups thing and I'm starting to find my way. One question:
When searching and downloading from binary newsgroups, it's possible to download video files in a million different formats - AVIs, WMVs, ISOs, IMGs, etc. Some are more desirable than others (for instance, for the purposes of burning the file to a DVD, ISOs are more preferable to me than AVIs, since AVIs take forever to convert and lose so much quality). But, as far as I can tell, there's no way to know what file type you're getting until after you've...
a) found the .nzb
b) downloaded the file
c) unrar'ed the file
My question is this - if I only want to download video that's only in ISO form or IMG form, is there a trick to figuring this out BEFORE you download/unrar (so far, I haven't found NFOs to be particularly helpful in figuring out the format of the file you're downloading....but maybe I'm not looking for the right clues)? Are there specific binary newsgroup search engines (or specific binary newsgroups) where one can specifically find IMGs/ISOs rather than AVIs?
Thanks, in advance, for any help!
If it's a multipart RAR you can download the first file and open it to see if there's an ISO inside. Other than that you may have to go with the title, filename, or NFO file.
Good advice on downloading the first file (rather than the whole thing) - thanks!
Well, you can do it the cheap way, or you can do it the better but more expensive way. I do it the better but more expensive way.
I use GigaNews as my news provider. I paid for NewsBin to use with GigaNews. I also pay for NewsBin's search feature. I know exactly what I am getting, whether it is an MP3 file, a FLAC file, an AVI or an ISO thanks to NewsBin. It tells you exactly what it is you are downloading. It has an intelligent way to aggregate parts of the same file so to you it just looks like one file, even if it's in a bunch of pieces. It's pretty slick.
I don't fool with .nzb files. They aren't necessary with NewsBin, although it does support them. -
I am using GigaNews....just checked out Newsbin - sounds pretty good. I'm going to check out trial. Thanks for the help
New software for finding duplicate video files by content
By vsp in forum Latest Video NewsReplies: 49Last Post: 24th May 2013, 17:59 -
fix Mp4 (Mov) files - binary/hex code
By octopus in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2010, 17:00 -
problem with DVDShrink finding files
By chaskar in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 16:48 -
mpeg files have this kind of image
By aruwin in forum Software PlayingReplies: 4Last Post: 6th Nov 2008, 10:06 -
finding GOP header by opening a file in binary mode
By VBMizio in forum ProgrammingReplies: 1Last Post: 30th Aug 2007, 06:38
