  1. Hi all
    Complete newbie here so apologies if I'm asking stupid questions..
    I've got a giant VOB file that I want to convert into a DVD. At this point, I'm not fussed about chapters or having a menu, I just want to get it onto a disc and play it back. Is it posible to do this easily with Videostudio? I've searched through these forums and have seen that it's difficult to get it to actually work with VOB files but I can demux it down into its component M2V and WAV files...
    Hope someone can help.
    Cheers
    Daz
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The only way to know for sure, is to try it. You will most likely end up demuxing it.
    Google is your Friend
  3. Member DB83's Avatar
    Jul 2007
    UVS will warn you that it needs to do some pre-processing when you attempt to add a VOB to either the time-line or straight into the 'make disk' module.
    Should work fine from there.
