I have a frustrating problem. Using Toast 7 (full version) or Toast 8 (Basic), DVDs have this annoying frame skip every few seconds. I have tried various media. DVD-R DVD+R DL and DVD-RW. All exhibit this problem. Brands have been Memorex and Maxell. I have tried burning the MPEG-2 files from an EyeTV 3 HD recording and .avis from the internets. Strange thing is that I finally tried Visual Hub (demo) and the DVD did not exhibit the frame dropping. However, with Visual Hub, there is no way to make a DVD with menus, which is a bummer if you want to make a DVD with multiple episodes of a TV show.
Roxio's official response to another poster with a similar problem is this:
"Ok, this is getting old. We have established that the problem is related to playback in some players for sure.
Yes, we know there are differences in the encoders from older versions of Toast to the current, however we are still within specifications and as such, that makes this not a Toast problem. We are still trying to work around it however but I am closing this thread down as the discussion is lingering on for months on end.
If you want us to look at your files, send me a private message and we can work from there on getting ahold of them and testing them."
found here:
http://forums.support.roxio.com/index.php?showtopic=16411&st=60&start=60
Should I forsake Toast and its easy interface with eyetv and nice menu creation utilities?
Is there some setting within Toast that might solve my problem?
Should I just buy Visual Hub?
Is there a simple way to create menus with some alternative application?
Could I encode with visual hub and use Toast to create a DVD menu for a DVD with multiple episodes?
Does Roxio suck or not?
yes, roxio does suck..i try to use toast 8 to make custom dvds with vob files and not only does it take a while but it seems to choke on certain files without any sort of error, on the other hand i can use mpeg2works for simple dvd authoring without any major problems and without re-encoding..granted, they don't have menus but at least i have a working dvd...
You all forget the golden rule:
Toast depends upon Quicktime for encoding.
If Quicktime doesn't have a robust set of codecs
to handle your internet avi's, it can choke, drop frame rates, etc.
Visual Hub, ffmpegx, et al do not.
A simple solution that you can do that makes the best of both worlds:
Have Visual Hub or ffmpegx encode your movie files to MPEG-2,
and then drag/drop those into Toast 8, and tell it to not re-encode
the assets.
If you set your bitrate targets correct in VisualHub ( see "Advanced" in manual)
you can achieve a perfect fit to DVD-5 or DVD-9 media,
without having to "squish" it to fit, and then by setting Toast
8's settings to not re-encode the media, you then can create a menu
and burn. Thus you get the best of both worlds:
Visual Hub's non Quicktime based engine
Toast 8's Menu creation."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
I get jerky video and some identical frames
By DavidGGG in forum DVD RippingReplies: 1Last Post: 23rd Feb 2010, 11:51 -
Neither Vegas Video nor WinDV show dropped frames count after capture
By korey99 in forum Capturing and VCRReplies: 13Last Post: 9th Apr 2009, 17:25 -
Visual Hub converting uncompatable .avi files?
By toxicquack in forum MacReplies: 2Last Post: 29th Jan 2009, 13:19 -
Hi i'm a newbie having huge problems with Visual Hub for the Mac Help pleas
By twiglet31 in forum MacReplies: 3Last Post: 7th Aug 2008, 15:06 -
Visual Hub interlaced video to DVD
By chrjohns in forum MacReplies: 1Last Post: 29th Jun 2008, 22:42
